RPMs surging after rebuild, looking for suspects
Old Oct 10, 2015 | 05:11 PM
Benjaminnesota's Avatar
Default RPMs surging after rebuild, looking for suspects
I have a 99 Disco with 128k, just finished a head gasket job. I fire it up and it runs great, for thirty to forty seconds. Then the RPMs start racing up near 3000 and the Service Engine Soon starts blinking at me. I double checked the connections on the throttle body, MAF, etc. Any possible suspects? Any ideas are appreciated, thanks.
Old Oct 10, 2015 | 07:40 PM
Twix's Avatar
How's your IAC? Any vacuum leaks?
Old Oct 10, 2015 | 08:00 PM
IAC looks ok, unless I installed it backwards. Any idea how to tell?
Old Oct 10, 2015 | 08:28 PM
ST_Farms's Avatar
Is it running smoothly other than surging. Most vehicals flashing cel means a misfire. Make sure nothing broke between maf and tb. May take can carb cleaner spray around if hit vacuum leak it will rev up.
Old Oct 10, 2015 | 09:05 PM
Default Throttle Cable on too tight
I slightly over tightened the throttle cable and it was causing the idle to surge. Thanks for the input, hope to have it solved.
iandemel
Mar 14, 2015 11:12 PM
Greenhead
Jun 24, 2014 08:48 PM
Nfbeckman
Jan 29, 2012 09:24 PM
free_kid
13
Feb 3, 2010 12:56 PM
JRdisco1
Feb 12, 2006 01:36 PM
