RTE 3" HD vs TF 3" HD
Old 07-11-2015 | 07:30 PM
coors's Avatar
Default RTE 3" HD vs TF 3" HD
Does anyone have any first hand experience w/ the ride quality between the two springs?
I have 3" TF HD springs currently and the ride is really rough. Am thinking about moving over to the RTE's. Anyone know if the RTE's ride smoother than TF HD's?
I just picked up an bone stock uber clean '04 , I'm getting ready to swap over a lot of "gear" from my wrecked '01 and would consider ponying up for the RTE's if they offer a softer ride.
Old 07-11-2015 | 07:38 PM
RTE's are a better quality coil set which usually are in fact taller then advertised.
You need to realize, anything over 3"s will not ride like a limo if you are looking for a true off road vehicle.
Just curious, what sort of trails are you planning to tackle? Also if you plan on running a 3plus " lift better check to make sure it will fit into your garage, I needed to modify my garage door some to fit mine in and under ground parking can be a little touchy sometime.
Also who's shocks are you going to be using?
Old 07-11-2015 | 08:15 PM
coors's Avatar
Mike! it's been awhile, welcome back!
I've accepted the not so smooth ride offered from taller springs and am okay w/ the non-Cadillac ride. But, was hoping I could "spring" into a softer spring w/o sacrificing my current ~3" over stock ride height.
I typically run rocky / muddy / off-camber trails.
The SD rack prevents me from gaining entrance into garages.
I'm running TF +2" w/ disconnected sways. I plan to swap them out a little further down the road w/ something more suitable.
Old 07-11-2015 | 08:55 PM
fishEH's Avatar
I don't think you'll see any improvement in ride quality. HD springs ride the best when heavily laden. The best my 3" springs ever rode was with 3 guys in the truck, a weekend worth of camping gear, and our 3 bikes on a hitch rack.
Old 07-11-2015 | 08:59 PM
coors's Avatar
I was afraid of that... Guess I gotta find me a big booty girl
Old 07-11-2015 | 11:07 PM
Frank4's Avatar
I have the RTE 3" and used to have the RTE 2". Both are pretty dang stiff. I am not sure ANY shock choice would help. I have run several types and it always ride like a wagon on concrete wheels.
Old 07-12-2015 | 07:49 AM
drowssap's Avatar
As said ealier unless your truck is alway loaded down you might want to rethink HD springs
Old 07-12-2015 | 08:08 AM
coors's Avatar
Noted. But that's not gonna happen. I'll keep a rotating stock of mouth guards on hand for my passengers.
Old 07-12-2015 | 08:39 AM
Alex_M's Avatar
You could always do a 2" medium lift with 1" spacers, I've heard of several guys doing that. Just a thought.
Old 07-12-2015 | 01:43 PM
LA_Disco2's Avatar
That's what I did. 3" of lift with a MD spring.
Quick Reply: RTE 3" HD vs TF 3" HD
