RTE old style D2 shock towers - install clarification
Old Oct 17, 2017 | 08:26 PM
Rover_Hokie's Avatar
Default RTE old style D2 shock towers - install clarification
I have some old style RTE front shock towers for my D2, and have never installed them. I am going to install them and a sort of suspension newbie question. It looks like the mounting points for the 4 studs on the bottom of the shock towers will line-up either way I place them in regard to the top shock mounting bolt going left-to-right or front-to-back. I know the stock shock towers top mounting bolt goes left-to-right, and that would seem to be the best way, but does it matter? I know some shocks have a single shaft with a nut on top, so was just wondering. Thanks for any input.
Old Oct 17, 2017 | 08:49 PM
I don't recall that it matters but I did mine so the bolt lined up like factory, seemed like a safe bet.
Old Oct 17, 2017 | 10:44 PM
ZGPhoto's Avatar
They won't, it's offset. It looks like it's a square, but it isn't
Old Oct 18, 2017 | 08:53 AM
OK, well I have them installed with the bolt front-to-back, and they mounted and lined up. I was just curious because as I looked at it when I was done, it seemed the bolt should be left-to-right as the factory shock towers were.
Old Oct 18, 2017 | 10:07 AM
ZGPhoto's Avatar
Front to back is correct for the RTEs
Old Oct 18, 2017 | 10:23 AM
Best4x4's Avatar
Yep x2 on RTE being front to back. On the OEM shock towers whenever I do a lift I rotate the towers 180 degree’s so the bolts can easily be removed.
TripleThreat
Apr 3, 2020 01:06 PM
CUpgt
Feb 22, 2014 04:36 PM
cminer
Sep 23, 2012 04:04 PM
Street Wolf
Sep 27, 2008 08:58 AM
DYNAMITE DISCO
May 12, 2008 08:14 PM
