rubbing tire
Old Dec 14, 2007 | 05:52 PM
LRDISCO's Avatar
Default rubbing tire
I just installed one of my 15" rims with 29" trxus tires and when i turn the tire all the way the tire barely rubs the front lower bumper on my disco 2. Should i trim it or leave it as it is? You can hear it in the cab when it scrapes. I stood outside while someone else turned the tire and it just barely hits.
Old Dec 14, 2007 | 06:50 PM
Default RE: rubbing tire
Sounds like it is time for a lift, that is alot of tire for a D2 with no lift.
Old Dec 14, 2007 | 08:05 PM
LRDISCO's Avatar
No its perfect without a lift the tires look very good on the truck i tested the tire going over logs etc.. and it doesnt rub at all . i love this new setup.
Old Dec 14, 2007 | 09:00 PM
Let it go, as the tires wear down they will stop rubbing when you turn.
Old Dec 14, 2007 | 09:02 PM
okdiscoguy's Avatar
You can adjust your steering stops so you can't turn that far, cut the bumper, lift it, or just wait till you rub the tire off. Your choice..
LR03NJ
Tires
Feb 25, 2009 10:16 AM
robbie1400
Mar 26, 2008 03:56 AM
robbie1400
Freelander
Mar 25, 2008 09:38 AM
qwertmonkey
Aug 10, 2007 10:16 AM
94LWB
Apr 28, 2007 02:22 PM
