Running bad!
Old Oct 15, 2009 | 11:55 AM
evittsd's Avatar
7th Gear
Got my OBDII. The codes are P0300, Misfire/Multiple cylinders and P0305-Misfire cylinder #5. I'm suspicious of the reluctor ring causing the misfires because of the one tooth missing and the bent teeth. I'm going to pull the trans this weekend and get a good flexplate with a good ring. Any ideas? Thanks!!!
Old Oct 20, 2009 | 06:39 PM
evittsd's Avatar
7th Gear
Codes P0300- multiple misfires and P0305-misfire Cyl #5. Checked the ECU connection. Looks good. Checked the fuel injector connections and they are secure with no damage. I don't know how old the plug wires are. I installed new plugs Haven't done any work on it for a week or more. That reluctor ring is stuck in my head. In my previous thread I called the flexplate the flywheel. The truck is an automatic. I have to get the exhaust back on before I can troulbeshoot. Also, the battery is draining within 2 days.
Old Oct 20, 2009 | 08:37 PM
Let us know what you find.
Old Oct 20, 2009 | 09:52 PM
mattrickman's Avatar
Fuel Pressure?
dparham
Apr 22, 2013 04:03 PM
cobbcj7
Apr 20, 2013 06:45 AM
starcraft1
Nov 13, 2011 08:14 PM
oljohnboy
Sep 14, 2009 03:01 PM
Bene
ROAMING WITH FRIENDS
May 11, 2005 04:33 AM
