Was running good for a while now P0304
Old Nov 30, 2022 | 10:37 PM
JoshD's Avatar
Default Was running good for a while now P0304
So the engine is stumbling after it warms up and throwing this code for cylinder 4 misfire. are any of these Rockauto plug wires and/or plugs any good or should I be looking elsewhere?
Plug wires:
Plugs:
Thanks!
Old Dec 1, 2022 | 06:43 AM
zski128's Avatar
When was the last time you did plugs and wires? Have you pulled the plug from #4 to see how everything looks?
I can tell you stay away from STI wires on rock auto, I had to swap them out and ended up going with OEM as I didn’t want to pull the intake for a 3rd time.
Old Dec 1, 2022 | 06:47 AM
mln01's Avatar
I recommend wires from STI.
Old Dec 1, 2022 | 01:38 PM
JoshD's Avatar
I guess this is why the miss and P0304. I barely tugged on it to get it to come off. Wires are not that old. STI brand. Gonna try some NGK.
Old Dec 1, 2022 | 02:11 PM
Harvlr's Avatar
Nice to find something that’s not expensive. A little difficult to replace the lead though.
Old Dec 1, 2022 | 02:35 PM
mln01's Avatar
That can be repaired pretty easily. I've done it.
Slide the boot further up the wire (use lube), then carefully remove the metal terminal from the broken off segment, neatly cut off the end of the remaining good wire and reattach the metal terminal. Slide the boot back down into place and reconnect to the spark plug. Good as new.
Old Dec 1, 2022 | 07:18 PM
JoshD's Avatar
I swapped out the wires with some cheapies from the local Auto Parts store and I know this is going to sound bad, but I hope the engineer that decided to put the coils behind the intake gets a bad case of the clap.
Old Dec 1, 2022 | 08:18 PM
Best4x4's Avatar
The coils were covered up due to the Bosch Intake Design, but they also honestly protect them. I got 235K out of a set of OEM coil packs. They were mounted in pretty much the exact same spot on a 96-99 D1 & 95-99 P38 GEMS. Just the intake design makes it a PITA and D2's with SAI don't help it either. Once you've removed the intake to do the job it's not bad at all. I can usually have the entire intake off in 30min. The trick to SAI equipped D2's or P38's is to remove the studs for the SAI stacks and replace them with bolts. That makes removing the intake a lot easier. There are plenty of short cuts you can do to save time vs what the shop manual says for Intake Removal BTW. Also the intake gasket is metal and I can't count how many times I've just re-used them without issue.
Wire wise STI have never let me down (unless quality has tanked), Kingsborne, and the NGK/Denso stuff isn't bad either. I agree I'd have just pulled a little slack and repaired that lead and called it a day personally. Spark Plug wise #1 NGK, #2 Denso, #3 Autolite. DO NOT use copper core on a Bosch setup you are only making yourself work harder when you have to pull them 10-20k later down the road, use Double Platinum and you won't have to worry about spark plugs for a very long time.
Old Dec 1, 2022 | 08:35 PM
mln01's Avatar
Hang on to the STIs. Don't throw them away. You may want to reinstall them when the cheapies give out.
Frank4
Nov 17, 2022 06:39 AM
Land Rover Doc
Aug 23, 2022 08:07 PM
Brandon318
Sep 15, 2021 02:27 PM
LR03NJ
Jan 17, 2018 09:50 AM
Zonk872
Jun 9, 2017 02:02 PM
