Runs ok but pipes cherry red
Old Nov 22, 2009 | 08:14 PM
dreager1327's Avatar
Default Runs ok but pipes cherry red
Just finished a soft rebuild on 1995 land rover discovery. The engines running ok and not overheating but exhaust from manifold to cats is glowing redhot. Am I missing something here or is that normal? First time to tackle a rover. Previously all I have worked on was 351 windsors and 4.6 mods. Would appreciate some input. Thanks
Old Nov 22, 2009 | 08:26 PM
larsdisc1's Avatar
8th Gear
convertors clogged?
Yikes
Old Nov 22, 2009 | 08:52 PM
gilder's Avatar
That is not normal. I wouldn't drive it until you get some feedback from Spike or DiscoMike.
Old Nov 22, 2009 | 09:49 PM
It was doing that when I first put back together. I put on new cats and new o2 sensors but that hasn't solved it. Maybe MAS? Or something with injectors? I have found out this a different beast than a ford or chevy. I am trying to figure it out myself but if worse comes to worst I'll take it too a shop. Mechanics are expensive in interior Alaska though.
Old Nov 22, 2009 | 10:01 PM
gilder's Avatar
I'm thinking it has something to do with the valve timing. Do you smell raw fuel in the exhaust? Do you see blue smoke? When you say "soft rebuild," what exactly did you do?
Old Nov 23, 2009 | 09:46 AM
okdiscoguy's Avatar
what cats did you use? There is a blockage between your heads and cats. I would not drive it until you get this fixed.
Old Nov 23, 2009 | 05:58 PM
Soft rebuild as in gaskets bearings and seals. Magnaflow cats and exhaust. I'm taking it in to a shop cause I just don't have all the diagnostic stuff. I'm hoping it's nothing drastic. Will post the findings next Wednesday
Old Nov 23, 2009 | 06:03 PM
I sure has hell would not drive it. It can't run OK and be turning the manifolds red, you are about to have a fire, and Disco's, because of all of the aluminum, will burn to the ground in a heart beat.
Fivespddisco
Sights N Sounds
May 21, 2011 11:11 AM
rambino
Mar 30, 2011 08:24 PM
Spencerfitch
Nov 13, 2010 02:42 PM
boldingm
Apr 21, 2010 07:56 PM
05LandRover
Apr 26, 2006 10:27 AM
