Rust prevention advice?
Old Aug 8, 2019 | 02:22 AM
Brandon318's Avatar
Default Rust prevention advice?
Hey all! I've been looking at adding a Range Rover Classic to the stable and while doing research notice just how wrecked those trucks get from rust. Got me thinking about ways to prevent rust on our Discos. My D2 is currently 100% rust free and I'd like to keep it that way if possible. Any advice? I saw Waxoyl (sp?) mentioned a bunch in the RRC forums.
Old Aug 8, 2019 | 05:50 AM
JUKE179r's Avatar
I've read waxoyl isn't the best method.
Keep washing it all on the outside, inside the door jams, and especially underneath. If you live in a colder area that uses salt/brine on the roads, you can wash the underside with warm water and baking soda to neutralize the salt and acids.
Old Aug 8, 2019 | 05:54 AM
redwhitekat's Avatar
Go to your local rust control centre get it sprayed with oil
I buy a few cans and every few months I spray everything under neath and inside frame
Old Aug 8, 2019 | 05:58 AM
JUKE179r's Avatar
Originally Posted by redwhitekat
... and inside frame
That's the key area!!!
Waxoyl is too thick to get inside the frame.
Old Aug 8, 2019 | 10:42 AM
Jason Feuerstein's Avatar
I use Fluid Film, which is some sort of sheep extract (don't ask me how they extract it). It'll last a couple months, and works basically the same as spraying with oil minus the rolling environmental disaster oil will turn your vehicle into.
Old Aug 8, 2019 | 11:34 AM
Brandon318's Avatar
I've heard that the bolts that mount the trailer hitch assembly to the frame can prevent debris inside the frame from passing through to drain holes, acting as a dam of sorts. I don't tow with the Disco; is it advisable to remove the tow assembly altogether?
Old Aug 8, 2019 | 11:35 AM
Brandon318's Avatar
I don't want to picture whatever the factory that produces this looks like inside. lol.
Old Aug 8, 2019 | 02:52 PM
whowa004's Avatar
I don't tow with my disco either but it makes for a great skid/slider when offroad as the *** end in these things is almost always dragging lol also it is a great easy to access recovery point with a shackle insert (blanking on what it's actually called...)
Old Aug 8, 2019 | 05:19 PM
Roustabout's Avatar
I use Fluid Film as well.
Disco Den
Apr 1, 2021 05:02 PM
Shmockiebaby
Jul 31, 2020 10:12 AM
lrnoob
Feb 12, 2018 07:16 AM
Spencerfitch
Sep 2, 2010 08:51 PM
apcollin
Aug 23, 2008 08:01 PM
