Rusted window channel (regulator ok)
Hello, so the driver's window dropped off the functioning window regulator due to heavy rust.
Apparently the bottom of the glass is glued to a rubber and metal channel, which is then attached to the regulator. See below
Surely to heavens with the industrial glues available one should be able to buy the channel and glue the window in?????
My local shop wants to get me a new window from the wrecker.....
Thanks
Thanks
Hey Lads and Lassies,
Searching for 2 hours, and found this alr 8022
Below is the link for the Brit Part. Comes in at 32 Canadian.
https://www.lrdirect.com/ALR8022-sup...-BRITPART.html
NIce to know as I live in a dry climate and if this one is rusted, there will be three more to come.
The ends of each runner was tack welded with a press and fell off easily when tightening. I JB welded it.
hole.
Roont (08-28-2023)
