Rusted window channel (regulator ok)
Old Jun 29, 2021 | 12:02 PM
kdscott100's Avatar
Default Rusted window channel (regulator ok)
Hello, so the driver's window dropped off the functioning window regulator due to heavy rust.
Apparently the bottom of the glass is glued to a rubber and metal channel, which is then attached to the regulator. See below
Surely to heavens with the industrial glues available one should be able to buy the channel and glue the window in?????
My local shop wants to get me a new window from the wrecker.....
Thanks
Old Jun 29, 2021 | 03:13 PM
kdscott100's Avatar
Hey Lads and Lassies,
Searching for 2 hours, and found this alr 8022
Below is the link for the Brit Part. Comes in at 32 Canadian.
https://www.lrdirect.com/ALR8022-sup...-BRITPART.html
NIce to know as I live in a dry climate and if this one is rusted, there will be three more to come.
Old Jul 26, 2021 | 07:02 PM
kdscott100's Avatar
so , 90 bucks with air fright incl to Calgary. Ok, so everything went well except the bolts that affix the channel. 3M 5200"ed the channel to the glass then the channel bolt holes where slightly smaller than the D2 channel. This resulted in me having to file out the bolt
The ends of each runner was tack welded with a press and fell off easily when tightening. I JB welded it.
hole.
robert.juric
Oct 2, 2019 09:55 PM
pthork
May 5, 2017 09:23 AM
yonatan
May 1, 2017 05:10 PM
CollieRover
Feb 9, 2015 05:51 PM
workinghard1713
Jun 21, 2013 01:21 PM
