The Saga Continues - My Wife's Discovery, No Start, Continued Diagnosis
Old 05-06-2022, 04:06 PM
Extinct's Avatar
Received 1,503 Likes on 1,066 Posts
Originally Posted by zski128
You might want to double check the RAVE but CPS only stops spark and not the fuel pump. The fuel pump should work under any conditions as long as the key is in position II.
Your issue does sound like an electrical problem. Have you printed of the starter/ ignition circuit diagrams and chased the paths?
Cps turns off injectors, not spark. It does that so you don't flood or even worse hydrolock engine
  #22
Old 05-06-2022, 04:15 PM
cvhyatt's Avatar
Originally Posted by Alex_M
Hey, I appreciate that very much. If you want something for it let me know, whether it be a little cash or some kind of parts.
I just want to pick your brain on a couple things. Happy to trade for that!
  #23
Old 05-06-2022, 04:37 PM
Alex_M's Avatar
It should kill both. Not as a protection mechanism, but because there's no RPM signal to tell the motor when to trigger both.
  #24
Old 05-06-2022, 04:38 PM
Alex_M's Avatar
Well I'd be more than happy! Looking forward to meeting you, as well as whoever else is there. I'll have a couple cold ones ready for you at the very least.
Did you sign up for the intermediate or advance trail? Every free day I've had from the last couple weeks has been dedicated to getting the rig ready. Made a lot of progress, but not going to get everything done.
  #25
Old 05-06-2022, 06:29 PM
cvhyatt's Avatar
yeah I signed up for both. I’m still doing repairs from the Moab trip!😂
  #26
Old 05-06-2022, 06:55 PM
Alex_M's Avatar
Was that an option?! I assumed they were at the same time.... Jealous of that Moab trip. That's the next place on our bucket list after we visited the Rockies a few months ago.
  #27
Old 05-07-2022, 08:31 AM
RoverMasterTech's Avatar
Totally wrong. Ecu will prime fuel system with key on. But will not run fuel pump without crank sensor input.
  #28
Old 05-07-2022, 08:35 AM
Also wrong. The crank sensor is the only input the ecu uses to determine the engine is rotating. No engine rpm = no fuel or spark. (how would it know when/how much to spark or inject if it can't determine tdc/rpm?)
  #29
Old 05-07-2022, 08:38 AM
If it runs on spray, it's 98% bad fuel pump. Even if you jump the relay, it doesn't mean you have pressure, or that the pump is even turning. No spark is crank sensor. If you haven't replaced it, replace it.
  #30
Old 05-07-2022, 08:46 AM
Alex_M's Avatar
Already mentioned I pulled the pump to confirm it worked and confirmed pressure by the pumps internal bypass/pressure regulator being triggered.also had not jumped the relay, but wired from the cargo area cigarette lighter directly to the pump so it comes on with the key.
Still intend to try the crank sensor though, even though I've changed it once. Only other real option is digging into the harness.
Quick Reply: The Saga Continues - My Wife's Discovery, No Start, Continued Diagnosis
