The Saga Continues - My Wife's Discovery, No Start, Continued Diagnosis
Old May 7, 2022 | 09:14 AM
  #31
RoverMasterTech's Avatar
Checking the crank sensor is easy. Hook up scan tool and monitor rpm. Crank truck. If you have rpm, it's working and you should have spark and fuel pump and injector pulse. If you have no spark but rpm on scanner, you have an issue with power supply to coils. You can check the negative pulse to coils with a harbor freight logic tester connected to positive batt. You can also test injector pulse the same way. Remember that 12v is always on with key on and ecu pulses negative to fire coils and injectors.
Old May 7, 2022 | 01:28 PM
  #32
Alex_M's Avatar
Lost my scan tool so we're kicking it old school until I find it. That's good info though on the coils, thank you.
Old May 8, 2022 | 04:37 AM
  #33
Extinct's Avatar
Originally Posted by RoverMasterTech
Also wrong. The crank sensor is the only input the ecu uses to determine the engine is rotating. No engine rpm = no fuel or spark. (how would it know when/how much to spark or inject if it can't determine tdc/rpm?)
Right, of course. I mixed up the security lockout which turns off injectors, not spark.
JP Lard
Apr 22, 2022 03:56 AM
Yellow Kalahari
Apr 9, 2020 10:08 PM
DUBLJDISCO2
Range Rover L322 (3rd Gen)
Aug 9, 2018 08:44 AM
Kathylynn
Jan 6, 2017 04:24 AM
Phiber Optik
Aug 3, 2008 06:03 PM
