SAI blanks
SAI blanks
Rebuilding my motor. Broke some of the SAI hardlines and while I'm waiting I'd like to plug the holes and run the motor. At least to get it out of the shop. Maybe more long term solution.
Anyone know of a suitable blank for the exhaust ports?
Also it'll just throw a SeS for the air pump correct? So voltage drop/resistance should fool the ECM?
Also any recommendations on a computer that can rewrite a Rover? My Snap on tool only does 2012 and newer Rovers.
Thanks and thanks
Thanks and thanks
Received 1,167 Likes
on
I just disabled the check engine light, black tape inside dash light cavity. You'll get codes 1412, 1415 all the time, so l just knocked out the light. Just read the codes every so often or when l feel there's a problem...and clear them or repair as needed (all except the SAI codes naturally).
Brian.
Brian.
on
Not sure, but l believe l've read on here that you can search for a none SAI engine ECM and change it out. And this will eliminate SAI codes from appearing. If l were ever going to sell the 03, this would probably be my course of action (and repairing check engine light). The 01 is going to "meet its maker", so to speak, when all is said and done.
Brian.
Brian.
