SAI Solinoid
Old Mar 9, 2024 | 06:50 PM
MRGMAN's Avatar
Default SAI Solinoid
Hi,
Could someone please tell me what should happen when I unplug:
1. The electrical connector
2. The vacuum hose
From the SAI vacuum control valve? Unplugged both of the above connections
with engine running and there was NO change in engine running. Thanks
Old Mar 10, 2024 | 06:16 PM
H20nSnow's Avatar
Originally Posted by MRGMAN
Hi,
2. The vacuum hose
Nothing that you'll notice. Supplemental Air Injection adds fresh air to the exhaust after it leaves the cylinder. The purpose is to add O2 to that stream so that the un-burned fuel has additional O2 so that - particularly when it hits the cats - it can keep burning to hopefully complete all possible combustion, reducing undesirable exhaust components.
Since this all happens after leaving the cylinder, that system has no effect on the way the engine produces power. It is emissions control only. When you disconnect any of the things you mentioned, you will be degrading the performance of the emissions control system, and will ultimately cause the failure - or worse - of the cats.
Old Mar 10, 2024 | 08:22 PM
MRGMAN's Avatar
[QUOTE=H20nSnow;893016]Nothing that you'll notice. Supplemental Air Injection adds fresh air to the exhaust after it leaves the cylinder. The purpose is to add O2 to that stream so that the un-burned fuel has additional O2 so that - particularly when it hits the cats - it can keep burning to hopefully complete all possible combustion, reducing undesirable exhaust components.
Since this all happens after leaving the cylinder, that system has no effect on the way the engine produces power. It is emissions control only. When you disconnect any of the things you mentioned, you will be degrading the performance of the emissions control system, and will ultimately cause the failure - or worse - of the cats.[
Wasn’t going to disable it just wanted to see if it was working. Thanks for the great explanation.
Old Mar 10, 2024 | 10:07 PM
Discorama's Avatar
SAI is used only at at startup with cold engine. You hear the air turbine making noise to blow fresh air into the exhaust to get the cats heated up faster. After a few minutes the SAI system turns off. When you keep the SAI disconnected you will get a check engine light because the emission control system detects that the SAI does not work.
Old Mar 11, 2024 | 02:43 PM
MRGMAN's Avatar
Got it thanks.😊
JUKE179r
Mar 26, 2025 04:07 PM
mackendw
Feb 6, 2024 02:15 PM
srockrae
Jun 24, 2014 10:45 PM
Fast951
Apr 18, 2014 02:12 PM
dgilaon4
Jul 17, 2009 12:52 PM
