SAI troubleshooting
Old Sep 29, 2020 | 10:59 AM
mollusc's Avatar
Also, I believe that these mounts will work to hold the pump. Much cheaper option than the LR official pieces.
http://www.amazon.com/Dorman-911-901...dp/B00902FZDG/
Old Sep 29, 2020 | 12:21 PM
Richard Gallant's Avatar
Thanks @mollusc I was going to add that today as well as the mod to eliminate the Aluminum pipes
Old Sep 29, 2020 | 09:05 PM
Kalliste80's Avatar
This is a great write up, something's wrong with my SAI and this is super helpful.
Old Feb 19, 2022 | 12:28 PM
Vegasdisco2's Avatar
4wd High
If I have the SAI system in my 04 Disco and now live in Nevada, would it be possible to completely remove the system, has anybody done this?
Old Feb 19, 2022 | 01:08 PM
Kalliste80's Avatar
I think you can but you'd get a lot of error codes/engine light. Side note: I thought I had a big issue with my SAI even after I installed a new engine and it turned out to be one of the catalytic converters that were clogged due to the previous engine's internal/external oil leaks.
Old Feb 19, 2022 | 02:18 PM
@Vegasdisco2 You can remove the SAI, but I believe you need a new ECU or it will toss codes like crazy
Old Feb 19, 2022 | 04:20 PM
Best4x4's Avatar
I've mounted the pumps with just bolts. Yes when it runs at startup you feel it more vs with the rubber mounts, but I NEVER have to worry about the darn thing falling off as those rubber mounts don't last long in TX at all.
Old Feb 19, 2022 | 07:21 PM
4wd High
thanks, I'll look into that, I really can't stand all that crap if I don't need it here in Las Vegas. they don't really have the same smog requirements that California does.
JUKE179r
Mar 26, 2025 04:07 PM
ReconDoc83
Apr 21, 2020 02:12 PM
gulfstream69xr7
Jun 1, 2015 10:31 PM
windowrattler
Jun 11, 2013 12:48 PM
Ranchrover
Oct 14, 2008 11:21 PM
