Sponsored by: CARiD
Impossible to start LR3 from 2005
Old Aug 7, 2013 | 10:26 AM
Phifross's Avatar
Default Impossible to start LR3 from 2005
Dear all,
I have a very big problem and I have tried already many things without any success.
Here the description of the problem and also what have already be done.
I would appreciate so so much any help, I'm really stuck !!!
Thank you in advance to everyone.
The first point is, I'm living in Liberia, no real dealers there, there is one dealer but no way, they know anything about this car, except how to charge you so much... 40US$ for one litre Water Coolant for example!!!!
Also the one who will solve the problem will not be able to see the car...
But I have tools and I have a MSV-2 from Blackbox that can help me.
Here is the description of the problem:
My car refuse to start so often, sometimes for days or weeks !!!
Suddenly the Water gauge temperature is going up, for no reason and at this time, impossible to start the engine. At this time too, the four flashers are on.
Sometimes, it's when the engine is already on, that the gauge is going up, at this moment the car suspension will go down, the RPM, the speedmeter and the distance are not working... The gauge can go up or down at any time.
More of that, I have many messages, Transmission faults, HDC not available, Special programs not available, Brake fault, Engine fault and so and so with many many lights on on the board... but again not always the same....
When the gauge is going down I have a lot less message but still some... just very few times I don't have any message or errors.
I guess that the fact I can't start the car is because the gauge is up in the red and it's a protection to not be able to start the car... but this signal is wrong !!!!
Because of this, I have tried to disconnect the Water Temperature gauge, no effect, the problem appear or disappear at any time. Same for the Oil Temperature Sensor, I have disconnet it without any result.
I have changed all the bulbs and disconnected the front and tail light, no effect. I have done this according to some forums and according to the funny way electrical schema of the LR3.
I have changed the Brake Light Switch, no improvement...
A hard reset is not helping too.
Now I have changed the battery, it means I'm sure that the battery is good quality (YUASA 90amps) and fully charged, I have checked, but sometimes the Water Temperature Gauge is going up, sometimes is going down... no reason and I'm not touching anything....
But something is new, yesterday for the first time, sometimes, when the gauge was up, the four flashers were off. Before, they were continuously on at any single time the gauge was going up. But they are always off when the gauge is normal.
It makes a difference, because I have noticed that the communication with the MSV-2 is impossible when the four flashers are on, but even if the gauge is up, if the flashers are off the MSV-2 can communicate, read faults and erase faults. It's impossible when the flashers are on.
When the gauge is down I have still many lights on with the message Transmission and blabla... when I try to erase all the faults, so often the gauge will go up ad the flashers will be on...
I have seen on many forums that we ignore the faults with starting with U.
Also I have noticed that I have some faults that are always here:
Airbag B0095 and B00D2 and HEVAC B1B78
I have been to the site: Diesel performance tuning and economy remap chip tuning for Landrover Defender Discovery TD5 Puma TDV6 TDV8 to know the meaning but it's not really helping me too much... Someone can tell me what to to solve at least these two problems ?
I don't think they are the origin of the problem, but anyway...
I have also many errors on the Body Control but they are Invalid Faults, someone knows why I have these invalid faults ?
And except that I have around 500 faults everywhere... I didn't check all of them yet...
Ah yes a VERY IMPORTANT POINT:
So often, when the flashers are on, if I press the reset button for the distance trip, they are going off and even the water Temperature gauge is going back to normal ? It is so strange isn't it?
Is it possible that it can be the Oil Temperature Sensor ? Or the Water Temperature Sensor ? For me I think it can be an Electronic card module? But which one ?
As a resume:
I have changed all the tail light bulbs
Brake switch
Battery
I have disconnected the Water Temperature Sensor, Oil Sensor, the front and tail light. I have also disconnected and checked the connection on the center, the computer, the radio, the ventilation, any problem.
Same for the transmission, the gear box and the HDC and the special program down the center console.
I have cleaned the MAF and the throttle
I have checked any single fuse everwhere, they are ok, no corrosion.
I have checked the ground wires on the driver and the passenger side, no corrosion at all, they are all well conncected.
Also my goal is to find why my gauge is going up suddenly... where come from this wrong signal. If I can solve that I would be very happy....
Now it's six months I have tried and tried and also waited to received some parts and tools.... I really would like to use my LR3
Thank you to everyone !!!!
Old Aug 7, 2013 | 07:41 PM
LR Techniker's Avatar
People say to ignore communication ( "U" ) codes, because they are almost always present and rarely give any indication or warning that they are there. Many things can trigger them, including low voltage.
However, since it seems that most of your symptoms are the result of a communications breakdown, the "U" codes are where you will need to look!
Write down all the codes in the car, in every module, including all the "U" codes. then clear them ALL and test drive, see what codes come back.
More than likely, one of the modules on the data bus is pulling the bus down, shutting off communications. Sometimes modules will tell on each other, and if one module pops up more often than others in the "U" code descriptions, it may be the offending module, or at least tell us what bus is effected (HS CAN, MS CAN, LIN BUS, etc...)
Old Aug 12, 2013 | 04:38 PM
Phifross's Avatar
It seems from another forum that it's a can bus problem...
Can someone help me please ?
When I scan my vehicle, some ECU are missing, here the list of the ECU missing.
SM129 INSTRUMENT PACK
SM129 PARK BRAKE MODULE
SM129 STEERING ANGLE SENSOR MODULE
SM129 ABS CONTROL MODULE
Any help would so much appreciated !!!
Thank you
Old Aug 12, 2013 | 04:56 PM
Certainly a crushed, shorted, grounded, skinned insulation, or just broken CAN buss cable could cause misery. If you don't have it, the LR3 tech manual and wiring diagram is a free download below.
GreenRoving
Jan 27, 2015 08:33 AM
Kalev
Mar 29, 2014 08:54 PM
bigsmokefarmer
May 13, 2012 12:35 PM
pittsburghrover
Jul 13, 2011 03:29 PM
Antmen
May 22, 2010 05:19 PM
