SAI valve leak - coolant??
Old Feb 5, 2019 | 10:52 AM
DiscoNickBK's Avatar
Default SAI valve leak - coolant??
So, I'm losing a little coolant, and keeping more pressure in the cooling system than I think is normal. I see some moisture on and around the clamps/hose at the thermostat junction. OK, I'll swap out the clamps. But today, I notice something else:
Sweet mother of God, that looks like coolant leaking from the SAI valve, doesn't it? How would that even be possible?
I'm not 100% sure it actually is, I can't quite place the smell. It could be oil of some type as well. But it definitely seems green...
Any suggestions for first steps? Gonna disassemble the SAI and pipe on this side this weekend.
Old Feb 5, 2019 | 11:00 AM
Best4x4's Avatar
It “should” be condensation from the exhaust if the gasket is seeping a bit. If it’s coolant you’ve got a cylinder getting coolant in a cylinder on bank 2.
Old Feb 5, 2019 | 11:06 AM
Red5's Avatar
If it is coolant, could be that heater hose right above the valve.
Old Feb 5, 2019 | 11:48 AM
Best4x4's Avatar
Yep or a heater hose
ems12
Jan 10, 2015 06:32 PM
BayerischeDisco
Nov 16, 2013 07:02 PM
kevin7723
May 30, 2013 09:01 AM
BrokeRover
Feb 22, 2012 06:13 AM
UpChuck
Jan 18, 2011 10:08 PM
