salvage value of 4.0 block?
Old 03-03-2014 | 03:47 PM
utah95's Avatar
Default salvage value of 4.0 block?
Does anyone know what the salvage value of a 4.0 block would be? IF anyone knows, I could also use the weight of a stripped block. Thanks in advance.
Old 03-03-2014 | 03:58 PM
abran's Avatar
I was told they are worth almost nothing as casted aluminum is not worth what extruded aluminum is.
Plus you would have to pull the sleeves to get a pure aluminum weight.
A buddy of mine closed down his Dad's transmission shop and had like 20 aluminum trans cases and they offered him almost nothing.
I have never tried it though, so could be interesting to see what they say.
On another note, I think the hoods, front fenders, and rear quarter panels on a discovery would fetch some good cash as they are aluminum.
Im going to test this theory next week and will post my findings.
Old 03-03-2014 | 04:04 PM
Charlie_V's Avatar
I'd like to know. Have some extras too...
Old 03-03-2014 | 04:12 PM
ZGPhoto's Avatar
Make a table with it, it will be more valuable and look cooler.
Old 03-03-2014 | 04:30 PM
04duxlr's Avatar
Plus it gives you a chance to leak fluids on the floor in your living room: V8 Coffee Table | eBay
Old 03-03-2014 | 04:34 PM
jafir's Avatar
Scrap metal is about $220 per ton last I checked. Aluminum should be higher.
No idea what a bare block weighs, but I think a complete engine is about 500 lbs. So even at scrap, you should get something.
Old 03-03-2014 | 04:55 PM
blamo's Avatar
It would make a hell of paper weight
Old 03-03-2014 | 11:28 PM
jfall's Avatar
Put it in the back of a pickup truck for snow traction weight.
Good until it rolls around and rolls out on a sharp corner into that porsche next to you.
Old 03-04-2014 | 09:29 AM
green-lantern's Avatar
I think I just read yesterday the engine was between 3-400 lbs. 358 or something like that.
Old 03-04-2014 | 11:30 AM
04duxlr's Avatar
Cast aluminum is worth about $0.50 per pound. With the liners, probably a little less. The block weighs maybe 75 lbs so you're probably looking at $35.
Quick Reply: salvage value of 4.0 block?
