Sanity check - Gap in the front windshield and top of A-pillar rain gutter area
The silicone that was used to patch up the hole in the front windshield and top of A-pillar rain gutter area (a number of years ago) needed to be re-done. I am going to use JB Marine Epoxy Weld to plug it up for a better seal against the weather elements.
I cleaned up the area. However, I do not remember seeing there was such a large gap (see circled in pic). It is the same sized gap on both driver and passenger sides.
Just doing a sanity check.... is the gap generally this large? Or I am wondering if perhaps there is some sealing piece that went missing when the front windshield was replaced a few years ago by the glass shop?
@Brandon318 actually is supposed exit the gutter and run down the edge of the windshield, that hole should be covered
Richard Gallant (05-12-2022)
This is how my 03 looks like on that spot.
Doesn't look so big on the photo.
Made a quick fix/test and put some tough and wide gorilla tape on the hole to direct the water on the glass.
Going to get a heated screen before winter as some of the previous owners have been cheap and replaced a heated with non heated screen.
Have had some water coming in for some time now apparently. Luckily the Fordium(rust) is only on the surface except the grommet on the firewall that has started growing downwards.
http://i.imgur.com/bgcGgZI.jpg
Honeybadgers
08-21-2021 01:44 PM
Brandon318
10-09-2019 03:26 PM
