Sans Airbag? & spring kit
Old Dec 6, 2009 | 07:07 AM
JoMar's Avatar
Default Sans Airbag? & spring kit
I have looked all over my 03 Disco SE and I cannot find anything that looks like an airbag suspension. Could it be that it never came with one? I keep hearing about the infamous airbag issues so I wonder if it maybe was taken out by a previous owner. I have coil springs on all 4 corners and standard shocks.
If I am swapping out springs and shocks to a 1-2" kit how difficult is the swap? I have access to an acetylene torch and moderate set of tools.
I am prepared to have hell with the bottom of the shocks because the brakes were so rusted I can only imagine snapping off one of the shock mounting bolts.
Those that have attempted it; is it overall too bad to do?
Thanks
Old Dec 6, 2009 | 07:12 AM
JoMar's Avatar
Skip the airbag question. I just rechecked the rave manual and I am not sure how I missed it. I infact do not have SLS. Sweet!
original question about time to complete or difficulty still stands.
Thank you in advance
lipadj46's Avatar
SLS was an option and not all discos came with it.
Doing the shocks and springs are easy, you don't need a torch, just get a good floor jack and jack stands and use the bottle jack to jack down the axle to get the new springs in. Lucky 8 has a how to video on youtube. None of the bolts are too hard to get off.
Old Dec 6, 2009 | 07:44 AM
Baylink's Avatar
Unless they were 7-seaters; it was supposed to be standard on the SE7's. (Was there an SD7?)
Old Dec 6, 2009 | 10:08 AM
Who's lift are you planning to use?
Old Dec 6, 2009 | 10:51 AM
oysterhead's Avatar
watch this: http://www.youtube.com/watch?v=Pkz0NTMFeYY
Old Dec 6, 2009 | 06:15 PM
JoMar's Avatar
Not sure DM. I wanted to go with brands I recognize. I am not familar with old man emu but they seem to be everywhere on the forums.
What one you suggest that would be comfortable? Maybe a mixed kit of bilstine and other springs?
Old Dec 6, 2009 | 06:17 PM
JoMar's Avatar
Originally Posted by oysterhead
Thank you Oysterhead. Gave me an idea of what I would be getting into. I have all of those tools including an air powered impact wrench. I do not however have a lift. I would hate to blow 500-600 more on labor. I need to find a place that rents lift bays like I had when I was in the Navy. On base we could rent a lift bay for $10 an hour. Even had tools there you signed out.
Old Dec 6, 2009 | 06:34 PM
lipadj46's Avatar
You don't need a lift or an impact wrench (though they are nice to haves). Like I said above you need a good floor jack, 2 jack stands and the bottle jack plus tools.
Old Dec 6, 2009 | 06:42 PM
jeffo's Avatar
Just for the record, I just installed a 2 inch OME lift on our DII. The parts are high quality and they are available from several sources. Expect 3 to 4 hours install time, and if your paranoid like me 15 minutes a day for the next week checking all the bolts.
