Scary situation today lol
Old Apr 24, 2022 | 03:06 PM
Mullins.cody's Avatar
Default Scary situation today lol
Was driving like normal just out and about and I look at the ultra guage and it's at about 205. Which was kinda odd cause it rarely goes above 200 even with the a/c on . Then it slowly starts climbing to 210. Now I'm already sweating lol. Then it jumps up to 217. I decide to pull over. Nothings leaking all the hoses feel normal. So I keep driving it slowly goes down to about 200. My normal highway driving temp is about 188. So I know something isn't right. Bad thermostat maybe?
Old Apr 24, 2022 | 03:54 PM
Alex_M's Avatar
Yep, sounds like your thermostat stuck for a minute but then opened up once it got hotter.
Old Apr 24, 2022 | 04:02 PM
Thermostat is less than a year old, maybe just got a bad one. Radiator is new, so is fan clutch. The only thing that isn't is the water pump.
Old Apr 24, 2022 | 04:24 PM
jastutte's Avatar
might was well convert over to the inline thermostat if you're going to be in there replacing the current one.
Old Apr 24, 2022 | 04:42 PM
Just ordered one from extinct actually lolWent out to see if it was still getting hot and I'm sitting in 88 degree heat at idle with a/c on and I'm not going above 195. That was very strange to see 217 randomly. I'm gonna say he was right about the stuck thermostat.
Old Apr 24, 2022 | 07:29 PM
Extinct's Avatar
That is the problem with the factory style thermostats - random excursions way above set point. Not that the inline thermostat elements never fail, I have had one fail. But you can remove it in 5 minutes without losing more than a cup or two of coolant and run with no thermostat element. Generally more consistent and reliable. I experienced your exact issue a few times before I quit using them, EVER.
adalton
Aug 31, 2024 04:25 PM
zeroone
Feb 22, 2014 10:42 PM
Gray8188
Jul 9, 2013 11:46 AM
mx468
Oct 19, 2012 03:04 PM
