SCUBA bottle to run air tools?
Old Dec 30, 2008 | 12:10 AM
discoxd's Avatar
Default RE: SCUBA bottle to run air tools?
http://www.oasismfg.com/Home.html if you want the very best
Old Dec 31, 2008 | 05:26 AM
pilsner's Avatar
the idea was that i already had everything but the $100 regulator (if i cant make one of my SCUBA low pressure ones work). i know it is a workable idea because back in the old days we used to make air tanks into our bumpers on the old K5 blazers we plowed snow with. just fitted them with a nipple/valve/regulator to drop down pressure from 3000psi to working pressure of the tools. im pretty sure it was kinda like having a bomb welded to our front bumper but geez, at the time we could still smoke INDOORS.
i guess the correct way to phrase the question was: anybody know a slick setup for mounting a 88cu ft SCUBA bottle (i get measurements in the AM) in a rover?
i was thinking maybe a combo spare tire/jerry can/hilift jack/vertical bottle holder type item mounting where the spare tire is currently located.
i know weight would be an issue but if i could weld it out of aluminum it would work. maybe...
suggestions?
thanks
Old Dec 31, 2008 | 05:34 AM
pilsner's Avatar
BTW it wouldnt matter what gas i had the bottle filled with (more or less, as long as it was inert or at least non-flamable-ish) because most big dive centers have mix-master machines that can mix almost any ration of O2/CO2/N2 that i was willing to pay for. my guess is that i could also fill it with argon or somesuch from a secondary tank available at a weld shop too....
as a matter of a fact if i wasnt concerned about the "breathability" of the air in the tank i could fill it from any HP compressor.
open to suggestions...
(NOTE : when i said we made air tanks into bumpers for our plow truck keep in mind that my step-father owns an irowworking company that is certified to do pressure-vessel construction/repair and that i have done a fair amount of pressure vessel weld testing [UV die pen, magnetic testing, and ulltrasonic inspections] so it wasnt as ad hoc and dangerous as it may have sounded.)
Old Dec 31, 2008 | 09:52 AM
discoxd's Avatar
http://la4x4forum.ipbhost.com/index.php?showtopic=30847 a thread on my local forum that may be helpful
Old Dec 31, 2008 | 01:17 PM
pilsner's Avatar
damn it! i KNEW i shoulda raided the volunteer fire station at home before i left!
i do believe it is time to visit the local dive shop and marina...
more to follow as ideas flow in
m3dragon
Feb 24, 2015 10:08 AM
wisconsinoverlander
Apr 26, 2012 10:24 AM
landRoverNewbie
Oct 13, 2009 11:39 AM
meltdowndave
May 31, 2008 01:10 PM
bigugly82
Mar 10, 2008 09:35 AM
