SD still hurting
Old Oct 21, 2009 | 08:45 AM
96Disco's Avatar
Default SD still hurting
I was losing 500 rpms when the disco got up to freeway temp just for a second then back to normal i had codes P1313 and P1316 so i put in new magnacores and bosch 4 new fuel filter all of which helped alot with power and lessening the amount and severity of the rpm loss but nothing has cured it my cel came on after i put everything in and had it cleared it still came up P1313 and P1316
thank you
jonas
Old Oct 21, 2009 | 09:02 AM
hilltoppersx's Avatar
how many miles are on your truck? are you losing any fluids?
Old Oct 21, 2009 | 09:53 AM
96Disco's Avatar
125000 and no lose of any fluids old fuel filter looked good inside and last oil change it wasnt too dirty it was after i cleaned it but that was before my last oil change
Old Oct 21, 2009 | 10:30 AM
Possible vehicle speed sensor.
Old Oct 21, 2009 | 10:54 AM
96Disco's Avatar
thanks guys i will check my vss from the search i did it sound like that is it but on one post i think it was spike said the vss wont throw any codes and i have 2 p1313 and p1316 they both say acura and bmw so i dont know what that means for LR and i coundnt even find them on the list i found somewhere on here
Old Oct 21, 2009 | 11:25 AM
96Disco's Avatar
i tried to locate my vss on discoweb.org but it isnt up is that an obsoleete site and if so where might i be able to find that info or a good place to get the rave
thanks for all the input
jonas
Old Oct 21, 2009 | 11:27 AM
96Disco's Avatar
found it at the bottom of your post thanks Mike ill look a little next time before i ask stupid questions again haha
Old Oct 21, 2009 | 05:04 PM
P1316 Injector Circuit / IDM Codes Detected
P1313 Misfire Rate Catalyst Damage Fault - Bank 1
Replace your VSS.
Old Oct 21, 2009 | 08:15 PM
96Disco's Avatar
can do ordering it tonight is there somewhere i can find on how to replace it
Bene
Jan 29, 2007 12:59 AM
russ00001
May 9, 2006 08:53 PM
budley62
Jan 24, 2006 01:28 AM
Charlie L
Jan 7, 2006 10:26 AM
