Sea foam no smoke
Old Apr 16, 2019 | 08:32 PM
Ben Matheson's Avatar
Default Sea foam no smoke
I've sea foamed a few cars in the past and always had plenty of smoke. Just tried on my Disco to hunt for exhaust leaks and it didn't smoke.. none zip zilch nada... What gives?
Put it in through the brake booster vacuum port on the manifold.,..
Old Apr 16, 2019 | 08:35 PM
Best4x4's Avatar
You did 1/2 to 3/4 of the bottle on a already warm engine, then let it sit 10-15min and restarted it and no smoke?
Old Apr 16, 2019 | 08:36 PM
bcurtman's Avatar
Did you put it in slowly, like 3 minutes to the bottle, shut it down, and then wait 20-30 minutes to go for a ride? Worked for me, but only smoked for 2 miles or so.....
Old Apr 16, 2019 | 08:37 PM
bcurtman's Avatar
Sorry I posted on top of you Best. We were answering at the same time!
Old Apr 16, 2019 | 08:42 PM
I used some tubing with spray stick from a can of wd40 as the final size to draw from the can and sucked down half can in about 90 seconds.
Motor was not hot but I figured I'd still get some smoke.
PS Best 4x4 check your PM's
Old Apr 16, 2019 | 09:55 PM
Best4x4's Avatar
If it doesn’t sit for 10-20min after you run 1/2 to 3/4 of a can thru it = I don’t it will smoke. If you just let it run without sitting the foam doesn’t have time to do anything. It would be more like adding it to your gas tank.
Old Apr 16, 2019 | 11:02 PM
Friday Night Disco's Avatar
I ran two cans of sea foam. First try I did not follow instructions. Little to no smoke. Second time I did exactly what the instructions said and crop dusted the neighborhood
Old Apr 17, 2019 | 06:02 AM
redwhitekat's Avatar
I was told that tests were done with sea foam that even on brand new cars with 0 km they performed the treatment and it smoked even in brand new lawnmowers never used it still smoked like crazy
Old Apr 17, 2019 | 06:09 AM
JUKE179r's Avatar
I emptied a whole Seafoam can into the tank and then add another 3/4 of a can into the intake on a warm engine. Waited 20-30 minutes and ran it like I stole it on the freeway. Ole Myrtle smoked like a carton of Winstons for a couple of miles.
Save the cans to show the police in case you get stopped by them. Just sayin...
redwhitekat
Aug 16, 2019 01:31 PM
lrnoob
May 3, 2018 11:22 AM
Island_Dave
Mar 24, 2016 10:04 PM
04BluDisco
Aug 20, 2008 07:51 AM
suveer
Jul 10, 2007 12:14 AM
