White Smoke in Exhaust After TB Clean
Old Mar 23, 2016 | 11:41 AM
Island_Dave's Avatar
Default White Smoke in Exhaust After TB Clean
Seeing a fair amount of white smoke in the exhaust after an air filter change and TB clean on my 95 3.9l GEMS. Followed the instructions on the can of TB cleaner which involved spraying the butterfly valve and intake WITH the engine running...
The white smoke is not thick but it wasn't present before and there is clearly condensation/water dripping form the tail pipe. Can't smell coolant though.
I've let it run for at least 20 minutes and cycle through a few startups now - still seeing the white smoke.
CEL came on after the TB clean also and is still on.
Initial thought was head gaskets were on their way out (!), but this doesn't make sense seeing as everything was clear before the TB clean.
Any ideas?
Old Mar 23, 2016 | 12:42 PM
I didn't remove nay of the coolant hoses to the TB, but are there any gaskets that keep coolant out out of the TB that might have been "upset" by the cleaning?
Old Mar 23, 2016 | 02:26 PM
hrhoward's Avatar
Get code from the CEL. I haven't done an upper cleaning since the early 90's but IIRC, it took a good while before the white smoke dissipated completely.
Old Mar 23, 2016 | 07:46 PM
TOM R's Avatar
Drive it smoke should clear, build up of chemicals and crap from the cleaning
Old Mar 23, 2016 | 08:07 PM
Thanks tom. The drive will have to wait until iv overhauled the brakes and hubs lol
Old Mar 23, 2016 | 11:01 PM
MrValingo's Avatar
anytime you clean the throttle body or do any chemical upper intake cleaning, you should make a few hard pulls up to 60mph. That'll allow any carbon to get sucked through the combustion chamber and out the exhaust
Old Mar 24, 2016 | 07:15 AM
TOM R's Avatar
I would have done brakes first as u need to drive now to clear that out
Old Mar 24, 2016 | 09:38 AM
Yeah hindsight is 20-20.
I guess i could just run it at 2000rpm for a few minutes in neutral
Old Mar 24, 2016 | 08:19 PM
fishEH's Avatar
Your neighbors will love you.
Old Mar 24, 2016 | 10:04 PM
Sorted. Wasnt too bad... problem solved i think
JuniorGF
Jun 23, 2015 01:11 PM
Pwn777
Jan 13, 2012 08:49 PM
Bensun
Jul 22, 2009 04:48 PM
kraelo
Mar 1, 2008 11:24 PM
jwmstang
Apr 12, 2007 10:31 PM
