seafoam instructions on DII
You couldn't have done it more wrong if you had tried.
If you want to do a successful cleaning the Seafoam must go thru they system as slow as possible. The fact that you made smoke, doesn't mean anything, I can poor a little engine oil in and of the hose, it will smoke like hell but not be benefical for the engine.
Just did the Seafoam induction cleaning & the throttle body cleaning. Did it using the lower connector nipple, 2 ft. of 3/16 tubing, and took a good 3 mins. to suck all the Seafoam in. Waited about 30+ mins for it to soak in really well, did the throttle body cleaning, then fired her up. It belched smoke for a good 10 mins., then took it out for a 20 min ride.
There is a huge difference...accelerates much smoother, much more responsive throttle. Thanks to everyone on here for the wealth of information you provide. A lot easier to do than I thought...the hardest part was getting the little tubing over the nipple.
Now, waiting for the engine to cool down and do an ATF engine flush. I think I have a sticky lifter, shows up at standing idle (sub 1K RPMs). After flush, filling w/ Mobil1 synthetic and see if that helps.
_________________
Khan
_________________
Khan
After I do the ATF engine flush, idle it for 30 mins., drain & refill w/ Mobil1...I should be just under 1/4 tank of gas left. When I refill, I'm planning on using the Seafoam then. Going to cruise around Bethesda & DC for a few hours, and try to enjoy the beautiful weather.
I did the induction cleaning in both our Discos as well- BIG difference in my 2004- but I think the 2000 was probably done right before I got it.
I took 4-5 minutes to let all the Seafoam filter through as well- worked great. Thanks again, Mike and everyone else!
Bark- Do you have a resource you're using to do the flush? I'd like to flush mine as well here in the next few weeks.
Thanks!
Pat
Thanks!
Pat
Did the engine flush...it was a piece of cake. Opened the drain plug, drained all the old oil, flipped the drain plug washer and put it back on. Filled with 6 qts. of ATF (I used Valvoline MaxLife Synthetic) and let idle for 30 mins. After, drained oil/ATF, removed oil filter, fit the new Mobil1 filter (1/2 filled with oil), and a new gasket forthe drain plug. Fill with 6 qts. of oil (I used Mobil1 10W-30). That's it.
I have to say, the bright red Valvoline MaxLife came out a really muddy blackish-brown color after only 30 minutes. A couple regular flushes along with synthetic oil will really break up all the built-up gunk.
