Seafoam Screwup...need help!
Old Dec 16, 2005 | 03:58 AM
williega's Avatar
Default Seafoam Screwup...need help!
Team,
I put 1/2 a can of Seafoam in the vacuum hose that connects to the valve cover while the engine was running and that was great...a lot of smoke.
I then turned the engine off and put the other 1/2 of Seafoam and now the car won't start.
I now understand that I shouldn't have put it in while the engine was off, but how do I fix it now?
Thank you
Old Dec 16, 2005 | 01:05 PM
Hank's Avatar
Default RE: Seafoam Screwup...need help!
Where did you put the other half?
Old Dec 16, 2005 | 01:28 PM
05LandRover's Avatar
new valve covers, new hoses????
is your disco still in warranty or out due to months/miles?
Old Dec 16, 2005 | 01:58 PM
mikemeyer0's Avatar
Give it full throttle while you crank on it, you should have put the rest into the fuel tank not into the throttle body while the engine was off. No you don't need new hoses or valve covers seafoam did nothing to these.
Old Dec 16, 2005 | 03:16 PM
btw, what is seafoam? what does it do?
Old Dec 16, 2005 | 03:45 PM
williega's Avatar
Team,
Thank you for the advise. My mechanic removed the spark plugs, cranked the engine and the stored fluid sparked out from holes where the spark plugs were (you have to be careful not to let the fuel land on hot stuff and ignite your ride). The he dried the wet plugs, put them back in and got it started again.
I let it run for 10 minutes and drove off the rest of the white smoke.
Thank you again
Old Dec 20, 2005 | 04:53 PM
anonimaus's Avatar
05LandRover, It will clean the crap out of the engine. The main thing you have to watch for is throwing a fault code, as it can foul the O2 sensors. As noted in this string, it can also foul the plugs.
biscothedisco
Mar 12, 2013 06:17 AM
malmberg
Oct 23, 2008 08:20 AM
starcraft
Apr 8, 2008 12:48 PM
1stDisco96
Nov 9, 2007 06:57 AM
JRdisco1
Aug 23, 2005 02:27 PM
