Seat heater problem
Old Nov 13, 2007 | 12:33 PM
starcraft's Avatar
Default Seat heater problem
The passenger side heated seat is not working on my 1999 disco 2. I checked the three fuses that are fitted under the seat (two 3s and a 40) and they look to be fine. Is there anything else I could check or do you think that the elements are shot. Please help. Thanks
Old Nov 13, 2007 | 12:37 PM
starcraft's Avatar
Default RE: Seat heater problem
I forgot to mention that the drivers side still works perfectly. Also, both the bottom and the top heaters on the passenger side went out all of a sudden (they just didnt work one day as opposed to glitching for a while). Thanks again
Old Nov 13, 2007 | 01:44 PM
S4poor's Avatar
IIRC those fuses are for the motorized seat adjustments. I am not sure any of them are for the heaters?
Old Nov 13, 2007 | 01:48 PM
The heater fuse is one of the three.
Does the seat heater switch ight up when you push the button? You may want to check the plug as use a test probe and make sure you have voltage to the elements.
Old Nov 13, 2007 | 01:57 PM
hobiecat's Avatar
You may also have a bad switch. Remove your heater switches and test the bad switch with the driver side. If it turns on the heating elements then you know you have an issue with the heating elements on the passenger side. If it does not turn on the heating element for the drivers seat, then you know you have a bad switch.
Old Nov 13, 2007 | 04:14 PM
starcraft's Avatar
When I turn the passenger side on the light lights up (as does the working drivers side for that matter). Where do i test for voltage going to the seat? How do I take the switches out? Thanks
ls1morethanyou
Jan 12, 2017 10:21 AM
98roverguy
Jul 10, 2007 05:11 PM
stanigu
Jan 18, 2007 04:25 PM
Willie 00D2
Dec 8, 2006 02:23 AM
ddugan
Feb 20, 2005 02:27 AM
