Second opinion steam cleaned piston
You can do a head gasket replacement with engine in situ. Not a big deal.
Use all-metal headgaskets and that will stop a slipped sleeve, but even if it didn't it is manageable to pin a sleeve with the engine still in the vehicle.
Get your heads decked. Pressure test your block. Rebuild with ARP studs.
You'll be fine.
You'll be fine.
@11chuck that is the general idea, it does assume you keep the Disco in good shape. You may also require a switch to ARP studs get a good confirmed torque all the way around.
https://www.summitracing.com/int/par...ake/land-rover that should be the correct part number
Posted a pic of a steam cleaned piston in another thread:
https://landroverforums.com/forum/di...e4/#post718634
The Deputy
16
11-04-2022 07:11 PM
