Second opinion steam cleaned piston
Old Feb 2, 2020 | 12:28 PM
keninnc's Avatar
I have not moved to Rotella 15w x 40 yet.
That is my next move. I’ve only done one oil change so far and that was with high mileage 10w x 40.
Old Feb 2, 2020 | 12:50 PM
11chuck's Avatar
Originally Posted by No Doubt
You can do a head gasket replacement with engine in situ. Not a big deal.
Use all-metal headgaskets and that will stop a slipped sleeve, but even if it didn't it is manageable to pin a sleeve with the engine still in the vehicle.
Get your heads decked. Pressure test your block. Rebuild with ARP studs.
You'll be fine.
How exactly would metal head gaskets stop a slipped sleeve?
Old Feb 2, 2020 | 08:18 PM
No Doubt's Avatar
They block the liner's vertical clearance.
Old Feb 2, 2020 | 08:38 PM
11chuck's Avatar
I assume a 94mm bore Cometic MLS gasket would achieve this then, right?
Old Feb 2, 2020 | 10:31 PM
Richard Gallant's Avatar
@11chuck that is the general idea, it does assume you keep the Disco in good shape. You may also require a switch to ARP studs get a good confirmed torque all the way around.
https://www.summitracing.com/int/par...ake/land-rover that should be the correct part number
Old Feb 7, 2020 | 06:03 PM
Extinct's Avatar
Posted a pic of a steam cleaned piston in another thread:
https://landroverforums.com/forum/di...e4/#post718634
The Deputy
16
Nov 4, 2022 07:11 PM
blakslee720
Dec 10, 2019 07:18 AM
Twix
May 28, 2018 10:52 PM
LR03NJ
Nov 3, 2017 05:47 AM
loanrangie
May 17, 2016 04:36 AM
