Secondary air pipe
Old 04-10-2010 | 03:20 PM
ROVERTECH15's Avatar
Default Secondary air pipe
Hey guys my secondary air injection pipe has seemed to crack and now it has a wicked exhaust leak.Does anyone know where to get one for a resonable price i checked ab and they want 219. for one seems like a bit too much for a little metal pipe looking to spend under 100 if poss
Old 04-10-2010 | 03:33 PM
vandev's Avatar
Default miami rovers
try miami rovers in miami florida. I get most of my parts from them and they have alot of salavage rovers. They just might have one. www.miamirovers.com.
Hope this helps, Thanks Chris
Old 04-10-2010 | 03:40 PM
GARovee's Avatar
Spray pb blaster on the nuts, let it soak, take the pipe off, goto automotive store, get JB weld, mix it up, put over crack, re-install. Don't waste money for the same effect.
Old 04-10-2010 | 03:41 PM
GARovee's Avatar
He'll.. Don't even take it off.. Put JB weld on it in the truck.
Old 04-10-2010 | 03:45 PM
tried that man no luck i even heated it with a torch and it will not break loose.plus it looks like upon further inspection that someone tryied to tighten it up and split it wide open.its pretty mangled from someone not knowing what they were doing.and my nature is to fix it right it is my 04 which is pristine so i need a new or used one seems they make them without bends now guess its a new design
Old 04-10-2010 | 05:02 PM
GARovee's Avatar
Since they get trashed so easy I think AB is gonna be your best option unfortunately. Those things just don't lay around used ya know. They junk them at dealerships and just put new ones on for the same reason.
Old 04-10-2010 | 05:04 PM
GARovee's Avatar
There's a used one on eBay for 99 bucks
ajh
09-12-2011 09:28 PM
haleyrover
06-23-2011 07:52 PM
John Doud
03-25-2010 08:22 PM
isofast
01-31-2010 01:23 PM
dillhole
06-03-2008 02:20 PM
Quick Reply: Secondary air pipe
