View Poll Results: What tire size does this customer believe is giving him 28mpg?
225/70-16
14.89%
255/65-16
6.38%
205/80-16
10.64%
245/70-16
0%
That's Crazy Talk!
68.09%
Voters: 47. You may not vote on this poll
The Secret to 27 mpg... Revealed!
Old Jan 31, 2014 | 05:57 PM
Externet's Avatar
Thumbs down
Smaller diameter tires will advance less distance per revolution and will spin faster. The odometer (driven by the wheels rpm) will show 27 miles when you have actually traveled 17 with that gallon.
Does this make some sense now ?
Old Jan 31, 2014 | 07:02 PM
Dan7's Avatar
Better to shell out $10K on a diesel swap, and when your odo hits7 digits, you'll have recouped your money.
Old Jan 31, 2014 | 09:23 PM
iambhooper's Avatar
More revolutions throws the odometer off, but it will cause you to hafe better gas mileage because your traveling slower than you think.
Old Jan 31, 2014 | 09:29 PM
dusty1's Avatar
not much of a price bump compared to a new cannibal or the likes, right? am I missing something?
Old Jan 31, 2014 | 09:48 PM
Dan7's Avatar
My GPR block was $6K...a $4K savings and I got a 3 year warranty.
Old Feb 1, 2014 | 10:26 AM
SuperSport's Avatar
After re-calibrating the UltraGauge to my Stock Tires 255/55-16, I got a rock solid 13.6 MPG. I just installed new tires 265/75-16 and re-calibrated UltraGauge again. Now I'm getting a Solid 14 MPG. That's half of his claim, I'm not too far off.
Old Feb 2, 2014 | 06:45 AM
OffroadFrance's Avatar
I believe it's ultimately all about rolling diameter and tire width which = friction, drag, +- adhesion, power absorption. A half worn stock sized wheel and tyre often returns far better mpg than new or super grip tires. Mind you, in the US petrol is so cheap who should really worry ..............however, when in Europe petrol is €1.57 euro per litre it's a real consideration or diesel at €1.27 euro per litre. When we first bought a house in France in 2003 (didn't live here then) diesel was €0.70 per litre and the £GBP to €Euro was £1.0 to €1.5 exchange rate now things are very different at £1.0 to €1.21 and that's higher than it has been for years. Still the euro is going down the pan slowly but not fast enough
Old Feb 2, 2014 | 09:29 AM
pinkytoe69's Avatar
How do you calibrate tire size on the UG?
I can only find displacement and fuel tank size.
Old Feb 2, 2014 | 09:47 AM
SDinDS's Avatar
So doing the € to $ conversion and litre to gallon conversion, your diesel would be about $6.47 a gallon!!! Ouch! If I lived there, I'd buy a VW Lupo 3L (I read it gets 78mpg)
As for the Land Rover, I didn't buy it for and it wasn't designed for fuel economy. I have a Volvo for that You might get 27mpg by tailgating an 18 wheeler going down a 27 mile hill.
Old Feb 2, 2014 | 11:36 AM
SuperSport's Avatar
I calibrate MPG and Distance (Distance deals with tire size):
Keep in mind, your in dash Speedometer will be off. I've verified UG speed with my GPS over a long distance and it's dead on.
The reason I bothered with all this is because I always hear horror stories about going with big tires and KILLING your MPG. I think that with the small diameter size change I made, and the fact that the 4.6 engine is no slouch, it didn't seem to negatively affect it. A Smaller engine, or much bigger tires would have definitely affected the outcome negatively.
Code:
Calibration....
Calibrate MPG/Fuel
MENU  Vehicle Setup ..  Calibration..  Calibrate MPG/Fuel
This calibration is used to fine-tune UltraGauge to accurately measure fuel usage. This calibration is critical, especially for vehicles
which use a MAP sensor, diesels and alternative fuels.
 For vehicles that use a MAP sensor*, see the menu section on Adaptive Volumetric Efficiency before proceeding.
 Prior to this calibration, consider performing the distance calibration. See the section: Calibrate Distance
 Calibration cannot be performed if less than 4 liters or 1 gallon has been used.
The gauges that depend on fuel usage will not be accurate until this calibration is complete.
Calibration Procedure:
1. Fill up the fuel tank.
2. Set the ignition to the RUN position (Engine Off)
3. Press and hold the UP key to cause UltraGauge to recognize the fill-up
4. Zero the Average MPG. MENU --> Gauge/Page Menu .. --> Zero Ave MPG, G/H.
5. Exit the Menu system
6. Drive until it’s time for the next fuel fill-up.
7. At the next fuel fill-up, fill the fuel tank and note the number of gallons/liters used (pumped). (Always use the same fuel
station and the same fuel pump)
8. Set the ignition to the RUN position (engine off)
9. Press and hold the UP key to cause UltraGauge to recognize the fill-up
10. Select MENU --> Vehicle Setup.. --> Calibration.. --> Calibrate MPG/Fuel, and change the value displayed to the amount
of fuel recorded in step #7. Press MENU when complete to set and save the calibration.
11. Exit the Menu system the cal is complete
Congratulations, you have successfully calibrated UltraGauge to your vehicle.
Alternatively, to improve accuracy, record and add the fuel used (pumped) over several fill-ups to improve accuracy.
Multi-fill-up Calibration:
a. Repeat step 6. Proceed to Step 8 after 2-4 fill ups.
of total sum of fuel recorded in step #7. Press MENU when complete to set and save the calibration.
Make note of the calibration factor displayed at the bottom of the screen. If you should ever need to clear your configuration, the
calibration factor can be used directly to set the calibration. Simply jump to step #10 and increase or decrease the reported gallons
until the calibration factor matches.
Ethanol fuel : Ethanol blends have less energy in the same volume of fuel. Switching between blended and unblended fuel will
result in inaccurate fuel usage for vehicles which have a MAP sensor and no MAF* sensor. It is recommended to either avoid
Ethanol fuel blends, or use only Ethanol fuel blends. Experience has shown that Ethanol results in reduced fuel economy.
* To determine if your vehicle has a MAF sensor, access the menu; MENU  UltraGauge Setup..  Version. This will display
MPG sensor: MAP, MAF or None
Reset MPG/Fuel Cal
MENU  Vehicle Setup ..  Calibration..  Reset MPG/Fuel Cal
Resets the MPG/Fuel Calibration factor to the factory default of 1.000. Use this to restore the calibration factor if the
MPG/Fuel Calibration is performed improperly.
Calibrate Distance
MENU  Vehicle Setup ..  Calibration..  Calibrate Distance
Use this menu item to calibrate all Distance Gauges. This calibration also directly affects the accuracy of all Speed, MPG and
DTE gauges. This calibration is especially necessary for vehicles which no longer have the stock wheels, tire sizes,
transmission, or rear-end differential. This calibration will also compensate for inaccuracies in stock speed sensor and the
vehicle’s distance measurement system. Perform this Calibration prior to all other calibrations.
**** Calibration cannot be performed unless a distance of at least 4 Kilometers or 2.5 miles have been driven. ****
To perform the distance calibration follow this procedure:
1. Align front tire with first mile marker
2. Reset the trip gauges: MENU  Gauge Menu  Zero All Trip
3. EXIT THE MENU
4. Travel to the 3rd mile marker (at 50+MPH), aligning the front tire to the mile marker
5. Select: Menu  Vehicle Setup  Calibration  Calibrate Distance
6. Change the value shown to 3.000 miles*, using the UP and DOWN keys
7. Press Menu to save and set the calibration
Once saved, the calibration factor will be displayed at the bottom of the display.
Many roads will have mile markers, but avoid roads that are not straight. Generally more markers will improve accuracy.
The greater your speed between mile markers the better the accuracy of the distance calibration
*If you chose to travel several mile markers, then enter in the number of miles actually driven, for example, 3.000 miles.
NOTE: Unplugging UltraGauge after calibration will not cause loss of calibration.
NOTE: Using the vehicle’s odometer to perform this calibration is pointless since the odometer and UltraGauge receive
distance information from the same source; the vehicle’s ECM.
NOTE: For best accuracy travel between markers at a high rate of speed.(50+MPH)
