security system ,1999 Disco
Help ! parked the truck last night. Tried to start it today and the idiotic **@# alarm system wont let it start. It cranks fine but wont run. Battery is charged, key fob works to lock and unlock and key turns on ignition. I get all the indicator lights (dash lights up like a Christmas tree). turn signals and side lights flash in unison. Horn honks if provoked ! Any suggestions on how to reset the alarm system?
doodle
Hi, and thank you very very much for the reply. I tried your suggestions but to no avail. The alarm system is alive and filled with vengeance.
I've also disconnected the battery for at least twenty minutes, re-connected and the alarm will not reset. I've tried the unlock/lock 3 times using the key fob and actually inserting the key into the door lock and repeating the lock/ unlock procedure 3 times and the demon still lives in the alarm system.
Perhaps calling a priest to bless the truck may help . But that's almost as expensive as the LR dealer with neither offering a warranty.
What to do now ? Is there any way to completely eliminate the alarm system or at least eliminate it's control over the engine and lights,horn, etc.?
