Seized Engine removal
Old Oct 31, 2021 | 01:51 PM
bmeier's Avatar
Default Seized Engine removal
Is it possible to remove the engine out of an 04 with the torque converter still attached? Engine is seized.
Old Oct 31, 2021 | 01:57 PM
The Deputy's Avatar
Yes. Just be extra cautious removing, pull straight out for at least three inches...to help prevent damaging trans pump and seal. Which, you should replace seal anyway.
Old Nov 7, 2021 | 10:38 AM
bmeier's Avatar
Not budging, cannot get engine to separate from the tranny, is there any trick to get er' out?
Old Nov 7, 2021 | 03:51 PM
The Deputy's Avatar
Are you sure all of the bell housing bolts are out, 14 to be exact. Someone just posted a picture of bolt pattern on another topic.
edit...look below.
Old Nov 7, 2021 | 03:54 PM
The Deputy's Avatar
abran
Aug 26, 2015 03:13 PM
aemnky606
Mar 23, 2015 06:50 AM
fj60disco
May 18, 2010 10:34 PM
twmj1953
Jan 18, 2010 09:41 AM
