Seized viscous fan nut
Old 09-21-2021, 03:34 PM
Harvlr's Avatar
Default Seized viscous fan nut
Does anyone have wisdom on getting the nut loosened? I have the pulley jammed with a pry bar and I’m tapping quite hard on my 36mm wrench. I’ve been soaking it in penetrating oil for a few hours. (P38 GEMS engine)
Difficult to get a good shot.
Old 09-21-2021, 03:38 PM
whowa004's Avatar
See if you can rent an air tool designed just for this. Had to borrow a friends one day and it made quick work of the stubborn nut.
Old 09-21-2021, 03:45 PM
Harvlr's Avatar
Oh wow. Thanks for the reply. That’s got to be a pretty specialized tool to fit in there.
Old 09-21-2021, 03:53 PM
whowa004's Avatar
It's a neat attachment that basically uses an air hammer type deal to break it free. That hi-frequency impact action does wonders.
Old 09-21-2021, 04:03 PM
Best4x4's Avatar
Received 2,297 Likes on 1,688 Posts
Standing from the front it goes Counter Clockwise to remove. I've used a beefy 36mm open end and usually hit straight down with a sledge and it will break loose. Or the Snap On tool style where you hold the Waterpump Pulley bolts with one tool, and loosen with the 36MM wrench.
Old 09-21-2021, 04:21 PM
Harvlr's Avatar
Thanks. I’ll give those ideas a try
Old 09-21-2021, 05:16 PM
Harvlr's Avatar
Got it. Clearly the “special wrench “ has way too much flex. Need a much beefier 36mm wrench, which I’ll have to buy for next time. I used a fairly beefy 12” crescent and a heavy hammer.
Old 09-21-2021, 06:04 PM
Extinct's Avatar
Received 1,503 Likes on 1,066 Posts
Neverseize on the threads going back, don't even tighten it as the fan load keeps it tight. Freaking ******** that tighten those.
Old 09-21-2021, 06:22 PM
Harvlr's Avatar
Good call. I use ant-seize on almost everything
Old 09-22-2021, 08:04 AM
H Hill's Avatar
A question of preference:
Do you use the silver anti-seize or the copper based? A good friend, a LR mechanic from Manchester England, always swore by the copper based product.
Just curious.
Quick Reply: Seized viscous fan nut
