Self Installed Lift
Old Apr 24, 2015 | 08:02 PM
LRlax11's Avatar
Default Self Installed Lift
Alright guys, Im putting on my own 2" Terrafirma Lift kit and i ran into a bit of a problem.. I can't get enough separation between the axle and the frame to fit the spring in.. any suggestions?
Old Apr 24, 2015 | 08:06 PM
abran's Avatar
Use your bottle jack on the axle and jack up on the bump stop.
Watch the Brake lines to make sure you don't snap them.
Old Apr 24, 2015 | 08:09 PM
LRlax11's Avatar
I already tried this and the brake lines almost snapped.. i can't figure out which bolts to unscrew to take the brake caliper off
or any way to take pressure off of the brake lines..
Old Apr 24, 2015 | 08:47 PM
Old Apr 24, 2015 | 10:29 PM
abran's Avatar
Crazy, I've installed 2 OME lifts and never removed the brake calipers or disconnected the sway bars. I guess I got lucky...8
Old Apr 25, 2015 | 10:18 AM
Never done a DII just RRC's and the 110. Never removed much of anything, I figured the DII might be a bit different. Either way better safe than sorry.
Old Apr 25, 2015 | 11:40 AM
Madlands's Avatar
My OME went on using the bottle jack method but my TF needed the bottle jack and the outer spring compressors from oreillys. Only need it on the front passenger side.
Old Apr 26, 2015 | 08:01 AM
LRlax11's Avatar
It's all done now! in the rear I just stretched the hell out of my break lines but in the front I went ahead and disconnected the drive shaft just to be safe. thanks for the help guys
Spencerfitch
Feb 10, 2017 10:57 AM
AK Rover
Dec 5, 2016 03:39 PM
caymandrew
May 9, 2015 10:05 PM
LRlax11
Mar 10, 2015 01:30 AM
jdhuegel1
Mar 1, 2011 08:26 AM
