series one brake system (pressure reducing valve)
Old Oct 3, 2008 | 08:46 PM
slave600's Avatar
Default series one brake system (pressure reducing valve)
hello all,
just got back from out of town. decided to take the rover out to play at a construction site near home and got it really nice and muddy!!! after cleaning some of the engine bay i noticed some paint that had been stripped under the brake master cylinder area on the inner engine bay/fender well. looks to be leaking brake fluid (the stripping agent)from the"pressure reducing valve"that is slightly in front of the master/servo unit the rover has. basically if it is a steel line i'll make a new one, but if it is theunit itself is a rebuild kit available and is it fairly straightforward a job?? never had one on another car i've owned. so what is it for and what does anyone know about it????
Old Oct 5, 2008 | 09:24 AM
slave600's Avatar
Default RE: series one brake system (pressure reducing valve)
maybe it is known as a bias or proportioning valve also!
Old Oct 5, 2008 | 09:49 AM
If the valve is leaking, either you have a bad fitting or a crack in the valve body, eithe r way you need to replace/fix it then do a full 3 pint brake bleed.
DiscoWest
Feb 16, 2017 06:03 AM
landy_ala
Oct 3, 2014 09:10 AM
Sam95disco
Nov 10, 2013 09:35 PM
pinkytoe69
Feb 10, 2012 07:56 AM
JBEGIN
May 20, 2008 11:35 AM
