Service engine light
Old 08-11-2009, 10:12 PM
csn4646's Avatar
Default Service engine light
I have a '97 disco with 84,000 miles and the service engine light came on. I have read some of the other threads and have read that it is just a maintenance check up. I called the dealer and they tried to charge me $250 for an oil change, to get the light off, and "other maintenance." I was wondering what the "other maintenance" might be. I have also seen that the service engine light is just for upkeep on the lr and not problems with the engine. So, I was also wondering if I turned the light off myself if it would end up haunting me down the road, or if it is ok?
Any answers help. Thanks.
Old 08-11-2009, 10:35 PM
lipadj46's Avatar
I don't think your truck does not have a maintenance checkup light, the DII's do not. If you get a light that means you have a problem of some sort. Get the codes read at autozone for free and get back to us ASAP.
Old 08-12-2009, 08:50 AM
You have both a maintance light and a check engine light on your D1. What color is the warning light, Red or Yellow?
Old 08-12-2009, 09:08 AM
csn4646's Avatar
The light that is on is the red service engine light. I have had the car since it had 50,000 miles and i have only seen the yellow check engine light come on, never the red service engine light.
Old 08-12-2009, 09:11 AM
You might do a search for resetting the service light. There is a relay behind the passengers kick panel, looks like a relay with a Rover emblym on it. Should see a hole that you can stick a paper clip wire into to to short/reset the system.
Old 08-12-2009, 01:16 PM
csn4646's Avatar
Ok thanks.
I will try that this weekend
kcferna
07-07-2009 08:33 AM
mr_boondoggle
Freelander
01-02-2009 09:32 AM
blackrover
08-20-2007 06:40 PM
97LANDISCOVERY
08-19-2007 04:10 PM
97rover
04-13-2005 02:19 AM
Quick Reply: Service engine light
