service engine light!
Old Nov 15, 2009 | 03:07 AM
SpdDemon426's Avatar
Originally Posted by btbaus
i read that if the service light is on and you get no codes, then thats just LR telling you to take it in to the dealer. is there anyway to clear the service engine light without going to the stealership?
Disonnect the battery cables and hold them together for like 30 seconds. That should clear the check engine light, but if there is a problem with the truck, it will come back on.
Old Nov 15, 2009 | 10:21 AM
Sure,
Might want to do a search for clearing maintance lights.
Are you a little mechanical/electrical?
Old Nov 15, 2009 | 11:56 PM
btbaus's Avatar
Originally Posted by Disco Mike
Sure,
yes. ill do a search!
Old Nov 19, 2009 | 08:40 PM
btbaus's Avatar
will running the engine with an aftermarket gas cap cause service engine soon light to show? cause i cleared the codes and the light came back on about 15 minutes after clearing the codes. the odbI display doesnt show a code and they only thing thats different is da gas cap. the OG gas cap is lost!
Old Nov 19, 2009 | 08:44 PM
Yes a bad/wrong/missing gas cap can set off a trouble code as a EVAP leak.
You can use a aftermarket gas cap but it must be a NON-VENTED cap.
Old Nov 19, 2009 | 09:21 PM
btbaus's Avatar
niiiice thanks!
kcferna
Jul 7, 2009 08:33 AM
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
blackrover
Aug 20, 2007 06:40 PM
97LANDISCOVERY
Aug 19, 2007 04:10 PM
97rover
Apr 13, 2005 02:19 AM
