Service Engine Light on at 42K mi???!!! HELP!!
Wondering if anyone has experienced a "service engine soon" at only 42K miles. Just got the car last week and drove it up from Florida to Michigan in a weekend. Oil was good, all fluids were good. No idea what would cause the light to go on. Please help!!
P0705, relates to the M&S, switch gear position indicator fault (XYZ Switch). It will cause it to go in limp home mode, which feels like reduce power, but it just locks the trans in 3rd gear. If you switch the car off/on it should clear, the M&S flashing. You will have to reset the code with your scanner. My 03 does this everyonce and awhile. If you just slowly shift into Reverse or Drive, and let it engage it should stop it from doing it. You can replace the switch, $199.99 at AB, it sits on the drivers side of the trans. They will get water in them, which will cause this. Not sure on the other codes, someone else will chime in.
Thanks
Thanks
kcferna
07-07-2009 08:33 AM
bangkuaidiscovery04
02-16-2009 11:53 AM
blackrover
08-20-2007 06:40 PM
97LANDISCOVERY
08-19-2007 04:10 PM
