Service Engine Light..9 codes.
Update: Sorry it took me so long to reply..The land rover had a compression test today and the results came back okay... told me that it needs both coils and upper intake gasket. I attached a picture of the old spark plugs..not sure how many miles are on them but know at least 30k
You can do the upper intake quick. You just need a little flat head screwdriver, 10mm and 8mm sockets with all kinds of extensions, and some pliers to crimp the hose clamps back together if yours are original. Also a magnet to fish out the front and back bolts and possibly the four small bolts on the coils. I also spray my plenum gasket with copper coat gasket compound but that's optional.
Do the coils at the same time because it is almost impossible with the upper intake in place.
OR pay him to do it.
Those plugs look pretty old.
Jmcbghs2012 (03-09-2016)
Yeah I have no idea how old the plugs are. The guy that owned the Land Rover before me said he never changed them. Im calling around in the morning to check on prices for the coils and gasket. Hopefully get it repaired tomorrow or Friday. They are going to do all the work at once. Luckily the shop its at does not charge us labor. All we have to do if provide the parts. Heres the things im having done to it...
New Thermostat
Radiator Flush and new coolant
Spark plugs and wires
Grease the drive shaft and ujoints
oil change
balance tires
and now..new coils and upper intake gasket
New Thermostat
oil change
balance tires
New Thermostat
oil change
balance tires
New Thermostat
oil change
balance tires
I used to use Bosch +4 platinum plugs but I think the champion 322s are just as good and about half the price. They look like the ones you have.
If I can suggest on coolant since you are having it completely flushed, if yours hasn't been converted from red dexcool you should use yellow Prestone. It is more forgiving of older engines and the problems they have.
Best of luck!
No wonder you got codes.
Wrong spark plugs.
All those stupid "Trick" spark plugs are just misfire magnets.
see http://engineodemaster.com for codes decoder
Put in the OEM plugs as noted in the owner's manual
Wrong spark plugs.
update: All the work was done. New thermostat, radiator flush, spark plugs and wires, coil packs, upper intake gasket. Compression test results were good. Still have slight rough idle. All misfiring codes are now gone..I have no idea what it could be..any suggestions? The gas is not old. ive filled it up multiple times with the highest grade. Thanks
I had a pulley in the garage so I swapped them and the wobble, and rumble, went away.
Jmcbghs2012 (03-23-2016)
Checked everything over and looked good. Not sure what to do about the rough idle. It runs great just soon as you stop it starts acting up. Having a pressure test done on the cooling system to see if any coolant is leaking. Im running out of ideas..any suggestions are appreciated. Ive replaced everything I can think of that would cause this issue. Im not a mechanic but ive researched as much as i could. Thanks in advance
kcferna
07-07-2009 08:33 AM
CandiMan
11-07-2008 10:57 AM
casanova00
07-28-2008 10:57 PM
