Service engine light, M & S flashing and turning over with no start...
Old Oct 18, 2015 | 06:43 PM
dandelion's Avatar
4wd High
Default Service engine light, M & S flashing and turning over with no start...
Hello and thank you in advance! Any help is appreciated as I live in the north where there aren't as many rovers or mechanics that are interested in working on them! I am also new to the world of LR and this is my first. Trying to be exact; gal here that is not mechanic but have tried to educate myself as much as possible.
I have a 2000 LR Discovery II. Last night returning home from work (vehicle was fine) I shut it down. Started back up again to change the C to F in the heating system. Chugged about 4 times (hard turn over) then started. Sounded tired. (Limp mode?) Immediately then the service engine soon light, M & S light (flashing) were on. I shut it down. Jumped on here to research. Prayed.
This morning, after what I read here on the forums, I checked the battery leads and they were loose. We tightened them. Tried starting- nothing at all. We cut the leads and put on brand new ones, tight! Gave it a try....turning over but not starting...So, that's something?
The gentlman that helped thinks it is the security system going into lock down. (I have no fob, was going to take of that this week) I am not so sure after all I have read. Since it responded (albeit slightly) to the new leads, couldn't it be battery, electrical related? (Manual says these two lights flashing is electrical fault with the automatic gearbox?)
What would I like from you kind folks? Any feed back: prior experience. I'd rather tow it to a foreign place here in town (costly mechanics) and have them plug it into a proper computer first before making a trip to the cities. As that same gentlman thinks I should tow it to the dealership for the security system. (About 3 hours away) Which he could be right?
Thank you again, please excuse my slight knowledge but I am receptive to what you all have to tell me.
Old Oct 24, 2015 | 05:52 AM
dandelion's Avatar
4wd High
Well, no bites here!
Like to close the thread as that is proper etiquette. My issue was a quick fix and labor cost. It was the crank shaft position sensor.
Good luck with your Rovers and see you next time!
cybercop
Oct 29, 2015 07:19 AM
importdave
Sep 25, 2014 10:18 PM
SolbergFanBoi
Mar 5, 2012 07:05 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
dancinbear54
Jul 9, 2008 07:18 PM
