SES light - Code P1416
Old Apr 14, 2008 | 08:13 PM
KeizerRover's Avatar
Default SES light - Code P1416
The SES light came on today and my code reader said it is a P1416 which seems to indicate something with the Secondary Air Injector system. I cleared the code and the light went off. What should I watch for now or be concerned with?
Thanks.
Old Apr 14, 2008 | 08:52 PM
Default RE: SES light - Code P1416
Emissions service is due.
Old Apr 14, 2008 | 09:07 PM
Okay, what all does that entail?
Old Apr 14, 2008 | 09:09 PM
I can't find the 1416 code, but I don't believe it is a service light for the secondary air, believe it is more of a failure issue.
Old Apr 14, 2008 | 09:56 PM
wooz797's Avatar
port air circuit
manufacturer specific- dont guess that helps
Old Apr 15, 2008 | 12:45 AM
P1416 SAI system fault (RH side) - air delivery not reaching catalysts
Suggestions???
Old Apr 15, 2008 | 07:15 AM
WolfPack's Avatar
I've heard of the SAI pump/valve actually getting clogged up, and all it needs is a good cleaning. Once that valve grinds to a halt, it'll trip a SAI failure code. You might want to try cleaning (I think a shot of carb cleaner up in the valve will work...cleaner, soak, compressed air, repeat.
If carb cleaner is not SAI valve safe, please correct me!
Old Apr 15, 2008 | 07:35 AM
jdelp's Avatar
Carb cleaner, WD40 or any lubricant/solvent is good. I clean my system about once a year, just remove all the hoses and you'll see the old oil and residue clogging the hoses. Your problem could easily be due to a loose hose, I've now had to zip tie a few on the vacuum pump for the SAI because they begin to slip off. I don't doubt that you could have a bad valve or pump, but try cleaning it and see if it helps.
millejdq
Jan 9, 2023 10:46 PM
99XJ
Aug 21, 2021 05:05 PM
Disco_Fever
Apr 26, 2011 11:59 AM
jck09
Mar 22, 2010 10:10 AM
microbc
Feb 20, 2009 07:55 PM
