SES Light - Codes P0455 and P0327
Hi all,
OK, so my SES light is on and I'm throwing codes P0455 and P0327. I read the description of the codes (Evap Leak and Knock Sensor 1 Circuit Low Input), but am looking for advice on where to start fixing the issues.
Also, can I reset the light myself without a scanner?
Thoughts?
Thanks!
Thoughts?
Thanks!
Thanks.
Could the two codes be related? I mean, I had no SES light at all (and hadn't for at least two years) and then when it came on and I got the codes read, they were both there. Logically, it would seem they are linked somehow, but I know logic doesn't always apply to my Disco!
Also, what do you think of this scanner? http://www.amazon.com/OBDLink-SX-Int.../dp/B004IAGNNG
Any thoughts on these two items?
Thanks.
Thanks.
on
Go to , CanOBD2.com - Tools find one above the 3100 and then go the Amazon.com where you can buy it for cheap. I use a 3130 with great results.
disco2 225k miles
same codes popped up po455 and po327.
although codes are unrelated seems like maybe something going on with ses for these codes to come together...im monitoring if the codes come back may gas tank is 1/3 full...and temps outside are 100...i wonder is that has anything to with that?
