SES Light - Codes P0455 and P0327
Old Jul 6, 2011 | 02:26 PM
jrkstore43's Avatar
Default SES Light - Codes P0455 and P0327
Hi all,
OK, so my SES light is on and I'm throwing codes P0455 and P0327. I read the description of the codes (Evap Leak and Knock Sensor 1 Circuit Low Input), but am looking for advice on where to start fixing the issues.
Also, can I reset the light myself without a scanner?
Thoughts?
Thanks!
Old Jul 6, 2011 | 07:17 PM
No, you will need to fix the faults then use a scanner to clear them
The 327 is a bad knock sensor on bank 1, the 455 is a gross evap leak, sometimes a bad gas cap but usually a bad leak that needs to be repaired.
Old Jul 6, 2011 | 09:04 PM
DiscoBenjamin's Avatar
Next time you put the gas cap on, look at it sideways and watch it screw in, it often clicks with 2-3 turns still left to go because they stop fitting at some point. That is where to start on the P0455.
Old Jul 7, 2011 | 07:41 AM
jrkstore43's Avatar
Thanks.
Could the two codes be related? I mean, I had no SES light at all (and hadn't for at least two years) and then when it came on and I got the codes read, they were both there. Logically, it would seem they are linked somehow, but I know logic doesn't always apply to my Disco!
Also, what do you think of this scanner? http://www.amazon.com/OBDLink-SX-Int.../dp/B004IAGNNG
Any thoughts on these two items?
Thanks.
Old Jul 8, 2011 | 08:58 AM
jrkstore43's Avatar
Bump.
Old Jul 8, 2011 | 09:44 AM
Your are either not thinking or thinking too hard, no, an evap fault can not effect a knock sensor.
Old Jul 8, 2011 | 03:52 PM
jrkstore43's Avatar
Thinking too hard! I couldn't relate the two, but did see another post on here somewhere with those two codes coming up together, so thought I might be missing something.
Any thoughts on an inexpensive, but effective, OBD scanner?
Old Jul 8, 2011 | 06:33 PM
catman's Avatar
I am pleased with my Ultragauge and it is only $60-$70.
Old Jul 9, 2011 | 09:27 AM
Go to , CanOBD2.com - Tools find one above the 3100 and then go the Amazon.com where you can buy it for cheap. I use a 3130 with great results.
Old Aug 25, 2021 | 01:43 PM
newworld's Avatar
Default po455 and po327
disco2 225k miles
same codes popped up po455 and po327.
although codes are unrelated seems like maybe something going on with ses for these codes to come together...im monitoring if the codes come back may gas tank is 1/3 full...and temps outside are 100...i wonder is that has anything to with that?
Kiki's Disco
Oct 4, 2012 10:47 AM
Disco_Fever
Apr 26, 2011 11:59 AM
willrok13
Dec 12, 2010 10:51 PM
utunes
Mar 14, 2008 08:02 PM
dbhook2
Jul 2, 2006 10:49 AM
