SES Lights Only On Startup After O2 Sensor Failure
Old Sep 9, 2025 | 11:15 AM
joefred16's Avatar
Unhappy SES Lights Only On Startup After O2 Sensor Failure
This is a really strange one. From my initial issue, I searched the forums, found a fix, but ever since remediating my lambda sensor issue I have not found a fix for what is going on as of lately.
Original Issue
  • After a year of topping off my coolant every month, I finally drummed up the courage to investigate and replace my blown head gaskets
  • I was also getting SES codes for the O2 sensors, so I replaced all four of them (direct Bosch replacement)
  • A couple of local shakedown runs and a 4hr roundtrip drive with no SES warnings proved my fix was successful!...until
  • Returning from that 4hr drive, I exit the highway and slowed to a stop for a red-light only to have the whole truck momentarily rough idle and shutdown
  • She restarted without hesitation, but was now showing SES. I keep a code reader in the center console, so I read the codes and was shown as many as 12 various codes, all related to O2 sensor malfunctions, MAF input, and various shorts:
    • P0102: Mass Air Flow (MAF) circuit low input
    • P0134: O2 Sensor No Activity Detected (Bank 1, Sensor 1)
    • P0135: O2 Sensor (ECM) Heater Circuit Malfunction (Bank 1 Sensor 1)
    • P0154: O2 Sensor (PCM) Heater Circuit Malfunction (Bank 2 Sensor 1)
    • P0155: O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
    • P0161: O2 Sensor Heater Circuit Malfunction (Bank 2, Sensor 2)
    • P0340: Camshaft Position Sensor "A" Circuit
    • P0414: Secondary Air Injection System Switching Valve “A” Circuit Shorted
    • P0445: Evaporative Emission System Purge Control Valve Circuit Shorted
    • P0448: Evaporative Emission System Vent Control Circuit Shorted
    • P1451: Evap Emission Control Sys Vent Control Valve Circuit
    • P1482: No DTC definition found. See service manual (DMTL Heater power stageDrive cycle A:Signal out of range - below minimum)
    • P1884: Coolant Level Sensor Short Circuit
  • After some research, some others have discovered that this behavior can be due to an issue with the lambda sensor wire melting or shorting somehow. I crawled under the truck to discover that I hadn't routed the bank 2 sensor 2 (downstream of cat) wire correctly, it got wrapped around the propshaft, and broke off
  • My exhaust was dented near the mid pipe causing a noisy exhaust leak anyway, so I dropped the cats section, moved the three "new" (read: now ~300 mile) not damaged Bosch sensors to the new Y-pipes, replaced the passenger-side downstream O2 sensor with a new one, and put everything back together. Making extra sure to keep the wiring away from any critical drivetrain components
New Issue
  • My new issue since this saga is that almost all of those SES codes reappear on the dashboard, but only at startup. So now, when I get ready to drive anywhere, my startup procedure is:
  1. Start truck
  2. Plug in code reader
  3. Read codes (all codes from above are returned except: )
  4. Clear codes
  5. Drive truck like normal
  • It doesn't matter how long I drive for, the codes never come back once they're cleared. But the second I turn the truck off, doesn't matter if it's for 5 seconds, 5 minutes, 5 hours, or 5 days, as soon as she starts I get the codes back
  • The only strange behavior I noticed is there is a little bit of power lag below 2k rpms, almost like she's not getting enough air. But I've already taken apart and cleaned the MAF sensor & connector with the appropriate MAF cleaner and electrical cleaner
I'm truly at a loss on what steps to take next. Any ideas?
Old broken O2 sensor
new exhaust
new exhaust
maintenance log
maintenance log
Old Oct 23, 2025 | 08:52 PM
joefred16's Avatar
This thread has been solved!
After weeks of banging my head against a wall and scouring the internet, I finally figured out that when the O2 sensor got shredded by the prop shaft it must have grounded out and blown fuse #2 in the engine bay fusebox. I took a look tonight, put in a good fuse, cleared codes and was able to perform multiple startups with NO MORE SERVICE ENGINE SOON LIGHT!
Hopefully this helps someone in the future.
O_Drizzle
Jan 30, 2024 06:08 AM
erick846
May 14, 2020 12:55 PM
KlamathMatt
Apr 17, 2020 05:27 AM
KlamathMatt
Apr 4, 2015 12:12 PM
mark 07
Mar 8, 2008 03:15 PM
