Share your measurements
Old Jan 27, 2013 | 11:52 AM
  #41
mongosd2's Avatar
The 80 axles use bigger R&P, front is 8.8" and the rear is 9.5" the cv's are 1.5" bigger than the LR's, the axle shafts are the same as a Dana 60, the stock ratio is 4.11, better brakes, full floating axles and can turn 37"s with zero issues stock.
Old Jan 27, 2013 | 02:14 PM
  #42
Robert Booth's Avatar
Originally Posted by jafir
I didn't take this picture special for this post, and my measurements are from a few months ago, because I don't have the disco with me at work, but I'm at 21.5 in the front and 22 in the back, the last time I measured, if I did it accurately. My tires are 255/85R16, if you need that info for comparing wheel well gap in another photo.
Is that the ARB deluxe Bar on your Disco Jafir ? I have a 2004 Disco 2 and really like the utility of the arb bumper but thought from other pics that i've seen, that it might stick out too much. It looks perfect sitting on the front of your truck!
Old Jan 27, 2013 | 02:37 PM
  #43
jafir's Avatar
It is an arb. They do hang over a bit too far for most serious off-roaders. I'm not one of those yet.
Old Jan 27, 2013 | 03:44 PM
  #44
ZGPhoto's Avatar
Do you have to run different wheels on the truck because of the bolt pattern?
Old Jan 27, 2013 | 06:13 PM
  #45
jpmiller's Avatar
I am 22 3/4 front and 22 and 1/4 in the rear on a 3" RTE lift and 275/65R18 Duratracs. Also have RTE Rocksliders.
Old Jan 27, 2013 | 06:34 PM
  #46
mongosd2's Avatar
yep...6x5.5 steelies with headlocks...
Old Jan 27, 2013 | 09:19 PM
  #47
ZGPhoto's Avatar
nice, sorry if you mentioned it, but how much wider/narrower are the FZJ axles when all said and done?
Old Jan 30, 2013 | 09:56 PM
  #48
taylor15's Avatar
I am running stock suspension, 18.75" in the front, 19" even in the back. Looks like I'm down an inch up front, but the rear springs are holding at factory spec.
Old Jan 30, 2013 | 10:02 PM
  #49
ZGPhoto's Avatar
Well I see your sig says "stock for now". If you plan on getting a bumper definitely plan on new springs!
Old Jan 30, 2013 | 10:06 PM
  #50
taylor15's Avatar
I have the money set aside for a winch bumper, sliders and 2" springs. We have been looking for something new for my wife and then I will start the build on this truck. hopefully by end of spring, first of summer
