shelf, under driver's seat, on frame, what is it for?
Save your money for a PowerTank, I go wheeling about every other weekend in Colorado. I picked up a 10lbs Powertank on CL for $130. Plus you can run numatic tools on the trail, and blow out your messy cargo area. You always have air and its about $16 to fill up the CO2 tank. Any company that services fire extinguishers will refill your tank for a deal. I have filled my tires up from 20psi to 40psi about 6 times on a half tank.
The tank is filled with liquid Co2. Same thing that carbonates Coke. The tank when pressurized will run about at 160psi, so plenty of flow for power tools and you can fill all 4 of your tires up faster than your buddy with the Via Air compressor can fill 2 tires. The Powertank has a regulator on it like a scuba tank...so you can control the air pressure once the main valve is open.
