shift linkage.
Old Feb 22, 2009 | 02:32 PM
tango123's Avatar
Default shift linkage.
Any advice on what good cleaner to use in cleaning a shift linkage for the transfer case of 97 disco =?
Old Feb 22, 2009 | 02:59 PM
Have you taken it apart yet or what?
Old Feb 22, 2009 | 03:42 PM
If all you want to do is crawl under the truck and clean the linkage then use carb cleaner.
Old Feb 22, 2009 | 03:58 PM
Well, no reply.
If you haven's done anything get, go power scrub the linkage on the drivers side, if that doesn't free it up, then plan on removing the console and going thru the floor.
Whatever you do, do not force the linkage or you will bend/break it.
Old Feb 23, 2009 | 12:56 PM
tango123's Avatar
sorry about for the long reply. Internet was out for a couple of days.
I haven't taking it out. I'll try do power scrub it underneath. If that doesn't work. I'll try open up the console. Any words of preacautions. I should be aware of in doing this?
Old Feb 23, 2009 | 01:01 PM
okdiscoguy's Avatar
Yeah, don't spray carb cleaner on it. It will eat away the rubber dust sheild and any seals on the top side if it pools up. Use some WD-40 or similar penetrating oil carefully on the linkage. Don't just shoot it everywhere.
The center console is a little tricky. Take your time and you will be fine.
hogweed
Jul 21, 2019 11:59 AM
cosmiccharlie
Jun 11, 2015 07:04 PM
DROVER1984
Jan 23, 2014 10:19 AM
HelenaRover
Sep 22, 2010 01:29 PM
sfjack
Jan 3, 2009 02:24 PM
