shifter ?
i have a qestions 1st, i have beenhaving prob removing the key but i noticed that if i shift from park to drive sometimes the key would come out,but yesterday my wife could not shift from park, and i tried and finally got it, it seems worsewhen its cold, i checked the linkage under neath appeared to be fine. so how to remove the console so i can check the shifter thanx. 1998 disco
ORIGINAL: bowtiecb
Disco I's seem to do this at times.
ORIGINAL: bowtiecb
mike the brake lights are working,and landzu when you say center cap are you talking about the shifter **** itself
ORIGINAL: Landzu
Yes the shifter **** has a cap that comes off and under that is the nut that holds the handle on once loose it will not let the shifter go all the way to park or other gears.
ORIGINAL: bowtiecb
it could be like mine was, when i popped the trim piece off around the shifter, i found a penny lodged inbetween the shifter and the park position. pulled the penny out, solved the problem. but i have a feeling i'll only be that lucky once with that!
try checking the tension on the shift linkage as well.
moneypit37
11-27-2006 02:20 AM
